Old 09-02-2011, 11:44 PM   #1
Lugnutt
Lugnutt's Avatar
Bed jacks into cab while off-roading
I gota think this must happen to most trucks of this type (72 short step-side bed 4x4). Since brand new, my truck bed bolts have mashed into the cab every time the frame torques while off-road. I'm ready to do some serious body & paint work now and wouldn't like to start the mashing all over again with new paint. Anybody found a good work-around for this problem?
Lugnutt is offline   Reply With Quote
Old 09-03-2011, 01:24 AM   #2
67_SS396
Re: Bed jacks into cab while off-roading
Box the frame, add more bracing to the frame or build a roll cage to tie it all together. Boxing the frame will help, but wont stop the flex completely. Same for adding more cross members. A well built cage would put an end to it.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 09-03-2011, 11:27 AM   #3
LONGHAIR
Some of it is probably coming from the rubber mounts under the cab too. The bed is "fairly" solidly mounted, but that cab can move around quite a bit. New rubber isolators would stiffen it up some, urethane is even more solid, but some guys say that the on-road ride is harsher than they like.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-03-2011, 11:34 AM   #4
Dunenutt
Newbee
Dunenutt's Avatar
Button head cap screws will give you a little more room. They are low and mushroom shaped, so they dont hit as easily. I also slid my bed as far as it would go in the bolt holes.
Dunenutt is offline   Reply With Quote
