More cluster questions
Need some advise on checking the gauges and wiring connector in my 72. Fuel gauge is the only one working, PO installed aftermarket oil and temp gauges below the dash. I would like to get the originals working. I have the cluster out, just need to know how to check things out. thanks
'85 C-10, with 93 LT-1 & 4L60 1985 GMC, lookin' for its big block motor - SOLD '72 Chevy C-10 Cheyenne-SOLD |
Old member
OK, first off you need to know if the truck came with the factory gauges are did he add them. If he added the factory gauge cluster the wiring bulk head is not right for the gauges. The wires in the connector aren't in the same spot for the gauges. You can swap them around and get them right but some one else will have to say which ones you need to move.
The circuit board needs to be for the gauges also and in good shape to start with no tears. As for the oil gauge it's mechanical it needs the tube coming from the motor ran to it. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: More cluster questions
all of the factory gauges are original.. PO just added the oil and temp because the old ones stopped working...just wanting to check out the temp,speedometer before i reassemble the cluster....
