Closed Thread
Old 09-04-2011, 12:38 AM   #3826
losthope
losthope's Avatar
Re: What did you do to your truck today?
Originally Posted by Rich 5150 69 View Post
What are the measurements for that tank losthope including the flange that extends out on the sides...Thanx
length with flange is 28 1/2 and width with flange is 23 and has a 5/8 flange all the way around......so tank size is 27 1/4 for length and and 21 3/4 width....from inside frame rail to inside frame rail is 27 3/4 and tank is 27 1/4 it will have a little bit of flange sitting on rails ...will most likely have to add flat stock on rails to get more meat or just strap the tank, and thats with the length going left to right looking at back of truck.......if you flip the tank length going tailgate to cab with gas filler at the back it will just be floating inbetween rails youd have to strap tank....you have to move cross supports.....the tank measure's 8inch's in height and if you put the tank flush to the bottom of the bed supports it hangs down to the bottom of side fenders (bottom of bed support braces to bottom of fender measures around 8 inchs),you would see the tank a little from the back if your not running a bumper.......if you notch the bed support braces like i seen some other guys do it would really tuck up in there... the only thing you would have to do to tank is make the filler stick straight up instead of at a angle......still gonna find out the ohms on sending unit..
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 09-04-2011, 12:44 AM   #3827
Rich 5150 69
Rich 5150 69's Avatar
Are you running with the stock gas gauge,,? VDO should be able to tell you, or go to Vintage Ford.....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 09-04-2011, 12:51 AM   #3828
losthope
losthope's Avatar
im gonna ask the guys on the 52-56 ford guys on the hamb somebody will know for sure, in my ford parts catalog's they show 6v and 12v sending units just dont say what ohms.!! it would be nice if its the same as stock truck gauge. i think i have another spare 54 ford gas tank (i have owned a couple 54's) if my tank install goes well and your intrested you can have it ,,if i still have it.
Timmy D.
losthope is offline
Old 09-04-2011, 12:53 AM   #3829
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Took lots of measurements to fit replacement quarter panel.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline
Old 09-04-2011, 08:57 AM   #3830
awbrown
Originally Posted by wutnxt View Post
Sounds like a very busy day dude
Sure was!! I remember doing it 20 odd years ago it was a snap , now I wonder how I ever did ... used to be fun , now it is too much like work !!! Glad I had AC in the shop ......
awbrown is offline
Old 09-04-2011, 09:02 AM   #3831
lakeroadster
Can't vouch for the accuracy of the following... found it online from a reputable company, DENNIS CARPENTER :
FORD FUEL TANK SENDING UNIT - Part Number 99A-9275
6 or 12 volt. MUST USE ORIGINAL DASH GUAGES 14-18 OHMS FULL 88-94 OHMS EMPTY
w/ Float & Gasket also fits Mercury 1953 1954 1955
http://www.parts123.com/index/google...X-99A-9275.htm
Hope this helps,
John
lakeroadster is offline
Old 09-04-2011, 02:25 PM   #3832
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
[quote=shrunken66stroker;4880531]
Originally Posted by 66-PMD-GMC View Post
You ever seen the top fuelers when they nail it and the tires get real tall???
Yes, but M/T street tires don't grow like eagle top fueler slicks. Not even close.
I am just curious about his goal with his build.
My 63 has stock wheel houses that I widened 4" and they have more than enough room all the way around for my 21" wide M/T. I like the stock sleeper look.
Some people put big wheel tubs in for visual effect.
Maybe he is going for the "back halved" effect.
The hood looks like it is off a pro stock.
I dunno. That's why I asked. It's an interesting direction he has taken.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 09-04-2011, 02:43 PM   #3833
bo-w
mounted and plumed the carb , valve covers and got the timing close. ........ she fired last night
bo-w is offline
Old 09-04-2011, 04:30 PM   #3834
el_bole
Hmmmm where to start....I bought a "new" bed.....(red one)
Took Old bed off(don't like the Chop done to it) what a bear it was...Me, Myself, And I took it off, oh yeah the cherry picker helped LOL
And the blue step side I am selling......FYI its a short bed complete with tail gate......
el_bole is offline
Old 09-04-2011, 11:51 PM   #3835
niterider65
niterider65's Avatar
started part two up the aframe upgrade for the cross drilled rotors
with new moog parts ... took a little time to gett the old ones out
tomarrow will put the new ones on .
niterider65 is offline
Old 09-05-2011, 12:39 PM   #3836
towersddg9
towersddg9's Avatar
will order up a driveshaft tomorrow, did some more wiring, running the bulk down inside the frame out of sight, really like the AAW kit, and the dual relay trinary kit from old air
towersddg9 is offline
Old 09-05-2011, 02:29 PM   #3837
Leadfoot Lambert
Leadfoot Lambert's Avatar
Lowered the rear using the Jeep TJ rear springs, I also changed the trailing arms because the old ones were bent, new poly bushings too! Does anyone have a spare drivers lower shock mount that you don't need? Mine is junk.
BEFORE
AFTER
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline
Old 09-05-2011, 02:31 PM   #3838
Leadfoot Lambert
Pic of bent trailing arms!
65 F100 short fleet
91 Heritage softail
94 Fatboy
13 Streetglide
Old 09-05-2011, 02:45 PM   #3839
glos55
glos55's Avatar
Nice Lambert! Brought it down quite a bit, Looks great!!!
glos55 is offline
Old 09-05-2011, 03:17 PM   #3840
Leadfoot Lambert
Thanks for the kind words, I would have gone lower all the way around but this truck will be a daily driver and will see 10,000 miles a year.
65 F100 short fleet
91 Heritage softail
94 Fatboy
13 Streetglide
Old 09-05-2011, 03:30 PM   #3841
Turkey
Turkey's Avatar
Finished the driver's side trim holes. Name:  IMAG0743.jpg
Turkey is offline
Old 09-05-2011, 06:04 PM   #3842
kieth
kieth's Avatar
Went out and looked at 2 other 60's trucks today, drove my gmc 300 miles, filled it up and got 17.2 mpg drove around 70mph with a strong sidewind, got 19mpg the first tank full but it was in town and really driving slow......Kieth 350--700r4, 3:73 31" diameter rear tires..
kieth is offline
Old 09-05-2011, 06:24 PM   #3843
doublebeetx
Finally a cool front came through the great state of Texas where I could work on my 64 stepside I got in April. I got the rivets ground out to remove the rear crossmember and the spare tire holder so I can install a Mustang in the rear. Still have to do a little more trimming but proud to be able to get that done.
doublebeetx is offline
Old 09-05-2011, 09:26 PM   #3844
niterider65
driver side spinde is on but im going to have to tear it back down the lower ball joints not setting all the way in.. ive going to have to get a press on the
lower un less it pops the rest of the way down .. also stared on the fire wall tring to get the thing to gether to drive
Old 09-05-2011, 10:05 PM   #3845
pdxhall
pdxhall's Avatar
Went shopping. Bought new bolts and nuts for the rear brake backing plates and new rear axle bearings and seals. I also bolted up the backing plates, removed the old bearings and seals, and did a little touch up painting on the rear diff.
pdxhall is offline
Old 09-05-2011, 10:39 PM   #3846
samuellg1977
samuellg1977's Avatar
Isn't that 700R4 nice? I love locking mine up on the interstate and just cruising along!!
Sam
samuellg1977 is offline
Old 09-05-2011, 11:29 PM   #3847
gpk1961
Had a horn/short and drain the battery issue. Tracked it down to a ground out under the dash. Got rid of extra wires and plug ins, wrapped and reconnected many wires. Everything is working!!! Electrical problems fixed! Fuel leak fixed! Broken bolt, removed! So interior paint and freshen up is next. Here are some shots from this weekend. gpk1961
gpk1961 is offline
Old 09-05-2011, 11:33 PM   #3848
niterider65
pics just a couple of more of what was done
Old 09-05-2011, 11:39 PM   #3849
glendale
glendale's Avatar
what about cutting the filler and get a flip down lic plate from any gm vehicle that had them and making it fill from the bumper?
glendale is offline
Old 09-06-2011, 12:04 AM   #3850
Vernski
No one bothered to tell me the bottom ball joint's have to be pressed in either a 10 ton press makes quick work of it only problem you have to take the bottom a frame out. There are some c-clamp that have a heavy duty bolt you screw down and it will push the ball joint up in there if the ball joint is smooth, but if has splines on it take it out and to a press it's the easy way to get it done IMO...Vernski
Vernski is offline
Closed Thread
