Have I done wrong? New alt with internal reg
I was having problems with my old alt draining voltage so I bought a new internal reg alt. The exact one recomeended in in the Frequently asked qurestion section. Wired it precisely as Frequently asked questions said except I didnt hook the black ground wire at the alt to anything. Alternator works fine and gauge show it is charging. However, the drain as shown on multimeter is 12.5 volts when engine is shut off.? disconnet red wire to terminal on back of alt ,where it is supposed to go, and drain drops to .25 volts. it is .25 volts. Have I done something wrong? truck is 69 C10 307
Posted via Mobile Device |
First of all...are you using this proceedure for checking for a battery drain?
To check for a battery drain: (1) Key in off position. (2) All accessories to off. (3) Disconnect NEGATIVE battery cable. (4) Place one lead of Multimeter on NEG battery post and the other on the disconnected NEG battery cable. (5) Read voltage on meter |
Re: Have I done wrong? New alt with internal reg
Yes. I unplugged every plug dash colum, every fuse at least twice. at this time I'm more concerned about why the new alt is drawing 12.5 than any thing else
Active Member
![]() Join Date: Jul 2007
12.5 vdc with everything turned off is good but check for battery drain like autoblue mentioned.
Ok...if you used the proper proceedure to check for a drain...then...with battery cables on and IGN in ON position...do a voltage drop on the ALT wire itself...if it is more than .5 volt...replace the wire...use 8 gauge wire if you need to replace it.
#6 | |
![]() Quote:
So to try and help you out here please tell us are you checking for a battery drain the way I described or not? |
Yes I am checking for drain as u described.at the Meg batt post. I under stand it is a massive drain
#8 | |
Old member
Sounds like to me you are reading voltage on the back of the alternator like it should. Red wire to alternator is a direct link to battery +.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Ok...now...do the voltage drop test on the ALT wire and see what you are reading.
Opps!! Stupid me! I said Volts when I meant mili-amps when checking for drain:
Sadly I have a pos multimeter frm Harbor freight an tool. Dosent have amp meter. Going to get one in the am. Between now and then any thoughts on why such a big drain at bat from a new alt. Thanks for ur help
#12 | |
![]() Quote:
However...you can do the voltage drop test on the ALT wire with the meter you have now...and if you find it has more than a .5 Volt drop...that would be the problem...then replace the ALT wire. |
BlahBlahBlah
This is a good thread. If there isnt already one like this over in FAQ this should go there. Nicely done guys, way to help out in an easy to understand way.
Mark
#14 | |
![]() Quote:
Also...did your old system have an external voltage regulator? |
#15 |
