Closed Thread
Old 09-05-2011, 12:03 AM   #2751
Tmwoodall
Re: What did you do to your truck today!
Originally Posted by rob32472 View Post
Love the wheels. Can you give more info on them?
20 x 8.5, come in polished, black, or as shown gray and polished lip. IIRC backspacing on the 8.5s is 5.25. Direct bolt on, not hub clearance or dust cap clearance issues. I bought them off eBay from Ron's wheels and they were shipped straight from showwheels. There are a few small imperfections in them , but you have to be examining them to find them. I didn't pay Coy prices and didn't expect a flawless wheel.
I'd buy them again in a heartbeat. I'll be putting 10" wide ones with 295 tires on the back.
showwheelsusa.com
I found them when another member posted (red 67 c10 out in California, with a really nice build, I forget his handle), posted a thread with them.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline
Old 09-05-2011, 12:01 PM   #2752
Bennett68C10
Bennett68C10's Avatar
Yesterday I started taking my doors apart to replace the inner bottoms and outer door skins. Sorry forgot to take pictures.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 09-05-2011, 03:05 PM   #2753
LadyBird
Got mine into it's permanent primer paint job Came out pretty good for "paint it in the driveway" paint job. Wheels, tires, and a lot more soon to come!
ImageShack.us
LadyBird is offline
Old 09-06-2011, 08:45 PM   #2754
RossRinSD
RossRinSD's Avatar
Ordered a MileMarker winch today... And, I should get a visit from the UPS fairy with some stuff from LMC tomorrow.
Its still 104 outside. I was hoping to get a little bit more done today, but doesn't look like thats going to happen.
RossRinSD is offline
Old 09-06-2011, 08:49 PM   #2755
willys72fleetside
willys72fleetside's Avatar
FINALLY, I got the paint work done all but the hood.
A USED TRUCK IS A LOVED TRUCK!
willys72fleetside is offline
Old 09-06-2011, 08:51 PM   #2756
67C10BUB
67C10BUB's Avatar
showwheelsusa.com
I think I've seen that truck...in my garage. Lol.
67 5.3L Build
67C10BUB is offline
Old 09-06-2011, 10:00 PM   #2757
flashed
I went and bought new wide trim rings for my 8" ralleys and put them on my wheels .It will be a while before the truck is home from the body shop for me to put the wheels on the truck .I cant wait to get the van rallys off and get the 8" rallys on as that will mean new paint on the truck.
flashed is offline
Old 09-06-2011, 10:04 PM   #2758
BMERDOC
BMERDOC's Avatar
I've got a lot done in the last two days! Many things have been checked off the list. I had to scar my rattle can paint job to do it but thats what the paint job was for. Click on the link!!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline
Old 09-06-2011, 10:05 PM   #2759
Shyguy
Junior Member
Shyguy's Avatar
Monday we started doing sheet metal work on my '67 swb stepper cab. I have never done any sheet metal work myself so my son was showing me how to do it. We removed the inner and outer rockers using hammers and screw drivers, not a fun way I don't think.
I cut off the old cab corners and cut and fitted the new ones, my son tack welded them. Also he cut, fitted and tacked the driver's side floor pan.
We removed the '73 454 from my '71 along with the SM-465 to prep them to put in the '67.
I helped one of my grandsons take apart the front clip off the '71 I gave him.
Today I ordered the seals and gaskets for the SM-465 from Rock Auto.
It felt good to finally start working on the '67 and since I gave the '71 to one of my grandsons I will be able to concentrate on the '67.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 09-07-2011, 12:16 AM   #2760
ItsRandy
ItsRandy's Avatar
Started block sanding the last coat of primer on my cab. I've sprayed 2 gallons of primer on the cab and swept up at least one gallon from my garage floor. sealer and paint are next!
ItsRandy is offline
Old 09-07-2011, 01:05 AM   #2761
Tmwoodall
That is the one. I h visited that page in your build thread many times. Also the name stamped in them isn't nearly as noticeable as it appears to be in photos IMO. Love the wheels.
Old 09-07-2011, 02:05 AM   #2762
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Filled it with wood from Lowes. Store is a few blocks away and I managed to drive alot further
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 09-07-2011, 10:53 PM   #2763
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Picked up my Electric Window stuff from ECE today.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-08-2011, 05:32 PM   #2764
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
I ordered this kit today from "No Limit" a vendor here!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 09-08-2011, 07:52 PM   #2765
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I installed a chevy only sticker on my back window today does that count as anything???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 09-08-2011, 09:00 PM   #2766
eagleuh1
eagleuh1's Avatar
Keep your head out of them window openings when rolling them up Magwakeener. They're pretty quick. Jim
eagleuh1 is offline
Old 09-08-2011, 09:16 PM   #2767
magwakeenercew2jh
Will do, Eagle.
Unless I'm ready to end it all.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-08-2011, 09:35 PM   #2768
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Originally Posted by ItsRandy View Post
Bought paint (on Friday), a close friend came over on Saturday and we block sanded my cab before the last coat of primer (only close friends will come over and help block sand). We only found a few spots that needed spot putty, we filled those and I am heading out into the garage to finish those in a few minutes. Tomorrow morning (before it gets hot) I am spraying the final coat of primer and hopefully, next weekend I will be spraying color on my cab. I have been sanding/filling/sanding/priming/block sanding/filling/priming/ block sanding etc., etc., and so on and so on for about about 8 weeks. I hope to show you all the results of all of my (and my close friend's) labor very soon.
http://67-72chevytrucks.com/vboard/a...1&d=1315178600
Looks someone was mighty thirsty before they started the paint process.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline
Old 09-08-2011, 11:06 PM   #2769
Tmwoodall
Finished prepping and got the first coat of Por-15 Chevy engine orange enamel on my small block. Top end goes on Saturday, if I can get a second coat on tomorrow night. I'll be picking up my March Track Serpentine kit saturday afternoon too!
Old 09-09-2011, 07:19 AM   #2770
RossRinSD
RossRinSD's Avatar
That should keep him up for a couple of days...
I broke down and ordered a few parts, proportioning valve and.....
a Plasma Cutter from Eastwood.
Old 09-11-2011, 02:37 AM   #2771
ItsRandy
ItsRandy's Avatar
Finished sanding the last coat of primer on my cab today. Built a paint booth in my garage with hi-tech 3-fan power ventilation. Paint tomorrow, I'm jazzed>
ItsRandy is offline
Old 09-11-2011, 01:39 PM   #2772
Boog
laying low
Boog's Avatar
Andy this is the first I've seen of this. That looks like a much more effective shock angle than the other upper shock relocators give on lowered trucks.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 09-11-2011, 02:03 PM   #2773
Andy4639
Old member
Andy4639's Avatar
Here is the link over in the Suspension area.
http://67-72chevytrucks.com/vboard/s...d.php?t=477839
Andy4639 is offline
Old 09-11-2011, 02:25 PM   #2774
Boog
laying low
Boog's Avatar
I know you will feel the difference in ride too.
Boog
primer is finer
Boog is offline
Old 09-11-2011, 03:10 PM   #2775
Andy4639
Old member
Andy4639's Avatar
Man I sure hope so! It has to be better than now.
Here is another addition I did.
New radio installed. Has HD stations, CD,SD and USB and Aux all. I have over 400 songs so far between the SD & USB. Best thing it was less than $90.00 shipped for free.
Andy4639 is offline
Closed Thread
