Old 09-02-2011, 05:15 PM   #1
MrTucker
MrTucker's Avatar
How do you turn the engine over manually?
This is probably such a stupid question that I hate to ask, but how do you spin the motor over manually?
I've done it on newer models by simply putting a wrench on the crank pully bolt, but the front of my '53 GMC 228 doesn't have a bolt.
How do you do it?
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 09-02-2011, 06:34 PM   #2
tmoble
Re: How do you turn the engine over manually?
it's not what I would call "spinning" but you can use a big screwdriver on the flywheel/ring gear. there's also special tools for turning by the ring gear teeth.
tmoble is offline   Reply With Quote
Old 09-02-2011, 07:06 PM   #3
mr48chev
mr48chev's Avatar
If you pull the plugs you can usually turn on over with the fan and fan belt.
If you working on the bottom side such as changing rod bearings turning it with a big screw driver or pry bar on the ring gear works or I have used a wrench on the clutch bolts or torque converter bolts a lot to turn one.
mr48chev is online now   Reply With Quote
Old 09-02-2011, 07:11 PM   #4
coralhead
coralhead's Avatar
I use two short bolts in the harmonic balancer pulling holes. Then you can use a bar or screwdriver.
coralhead is offline   Reply With Quote
Old 09-02-2011, 08:22 PM   #5
magicoolbus
magicoolbus's Avatar
You can also put it in gear and push, espcially if the plugs are out. In absence of a bump starter, I use this to get engines on TDC for setting dizzies. Easy to make uber small adjustments when trans is in 4th. Can't do this with an automatic so I use a flywheel turner sometimes too.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 09-02-2011, 09:05 PM   #6
booger1949
them motors dont have much compression so if the fan belt is still on it just grab the fan an push r pull it an it should turn right over
booger1949 is offline   Reply With Quote
Old 09-05-2011, 02:25 PM   #7
FFredo
If you pull the plugs you'll have zero compression. If it feels tight thats a good thing because it points to a nice seat on the piston rings.
FFredo is offline   Reply With Quote
Old 09-06-2011, 03:49 PM   #8
MrTucker
MrTucker's Avatar
thanks guys. i'll try these tactics out.
fyi - there is no fan belt and it's an automatic. I'll try the 2 bolt/pry bar method
Old 09-06-2011, 04:47 PM   #9
Dan Bowles
AD Addict
Not sure on the GMC motors but if you notice on the same era Chevies there is a 1" or so hole in the splash apron behind the grille. They still had the ability to use the hand cranks of old. I happen to have one from an IH Super C that fit in pretty good. It is a 16 mm bar with a pin through the end. It is the same as an old Ford jack wrench my employer used to produce. I use ours now and again and have cranked over our 1 1/2 ton '49 with a 235 to verify the valves weren't stuck! Never tried to crank start one, just turn it over.
Dan Bowles is offline   Reply With Quote
Old 09-06-2011, 04:53 PM   #10
MrTucker
MrTucker's Avatar
I'd love to see a picture of that!
Old 09-06-2011, 10:15 PM   #11
Dan Bowles
AD Addict
I'll have to take one. My son looked and said "hey, this hole goes all the way through" and the radiator is actually bumped up in the center to clear.
