8848stro
![]() Join Date: Mar 2010
Re: 63-72 Chevy P/U Rear Shock Mount System
So in other words,you can unload the coils and use coilovers with these brackets?
![]() Join Date: Jul 2010
I wouldn't recomend it. We used to make a coil-over conversion kit for C-10's, it was a slow seller. Some compaies still have them available. The mounts are plenty strong, but really not designed for the spring load. For the most part, I can't see any ride quality or performance increase (other than spring preload adj.) gained from coil-overs vs. coil & shock. There may be a slight disadvantage with a coil-over by not leveraging the spring.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
8848stro
Ok- thanks,just askin!
Old member
I ordered this kit this past week and can't wait to get it installed.
robnolimit, Thanks for answering all my ?. I'll post pictures as I install it. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Rob thanks for your time this afternoon, I'll be in touch shortly to order the shocks, relocator kit & springs. I really need some ride quality back before my wife shoots me, she's tired of bounceing...
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
