bag bag!!! bag question
70 c10 short stepside im bagging, i made the lower cups on front for low control arm.. i made it 4 1/2 in. wide and 2 1/2 in. tall... i thiink the height is ok but im not sure about the with, is 4 1/2 ok or is it bigger.. i think im going with 2600 slam specialitys
Sofa King Crazy!!
Re: bag bag!!! bag question
You may want to post this in the suspension area and let the gurus there help ya out. I think mine are almost 6.5 if I am not mistaken.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
I'm making mine 8" around. Bigger better, no rub.
I just got in a few sets from thorbecke bros they measure 5-7/8 diameter and 2-1/4 tall and I usually trim them down to 1-1/4" tall unless you are looking to lift the front of your truck. I would definately make them larger in diameter to match the bottom of the plate on the air bag.
Not to rip on you mxjunkie80 but bigger isnt always better because as long as the height of the lower cup allows you to clear the bag on the control arm when completely deflated then you are just adding unecessary weight to the system. |
VA72C10
![]() Join Date: Mar 2008
are you speaking of the cups that fit in the stock control arm and the bag mounts to it or a cup welded into the bottom of the arm (circle cut out of the arm) that allows extra air pressure to be in the bag at the same drop because the bag is physically?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#6 | |
Yes we are talking different things! Will the 2600's fit inside an 8" cup though? I thought max diameter of the 2600's was 8"
If max diameter is 8" and you use a 8" diameter cup, it should fit fine. Of course inner diameter is slightly smaller. Actually I'm not even sure what size my front bags are. But I'd hope they fit with that big of a cup. If not, I'll make it work somehow.
yes im talking about the cup that sits in the control arm...
#10 | |
low n' slo
![]() Join Date: Mar 2009
i believe my cups are 8" and by dominator 2600's came super close..too close for comfort that i swapped them to the 2500's just in case. but i think slam bags dont expand when deflated so you should be good. set the bag in the cup and see how much room you have. remember they inflate up at an angle, not straight up...just something to keep in mind as the suspension travels
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
i made mine 9" diameter
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
