Old 09-04-2011, 04:06 PM   #1
gotchamel
weight of a bed?
Its been explained that a bed can be removed easily by a few guys or a cherry picker but does anyone know the weight{including tailgate}of a shortbed bed?Thanks,Mel
gotchamel is offline   Reply With Quote
Old 09-04-2011, 09:22 PM   #2
hugger6933
Re: weight of a bed?
This is purly an educated guess. I would say that a complete short bed [with metal floor] is 750-825 LBS. The long bed will run about 200LBS more. These beds seem to be real similar to the late model beds in that catagory. Jim
hugger6933 is offline   Reply With Quote
Old 09-04-2011, 10:59 PM   #3
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Jim, I'm guessing too but I'd say your high. I lifted a 99 silverado 6.5 box with a friend and I'd say we had about 200 lbs each with tailgate on. These older ones have a little thicker steel so I'd guess I would say it would be around 450.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 09-04-2011, 11:59 PM   #4
KrazyRay
KrazyRay's Avatar
I agree with VW...450 lbs
KrazyRay is offline   Reply With Quote
Old 09-05-2011, 12:55 AM   #5
CG
BlahBlahBlah
Two guys can very easily lift off a short bed. No idea if the guesses so far are even close.
My son and I went to lift one off once and it was incredibly heavy. Turns out the thin piece of metal someone stuck in there for a bed floor wasn't thin after all.
Old 09-05-2011, 01:09 AM   #6
ItsRandy
ItsRandy's Avatar
A buddy of mine and I lifted a long bed off of my truck and put it in my back yard, but, no tail gate and no floor (it was wood)...we're both kinda old so it wasn't all that heavy, 350 - 375lbs.
ItsRandy is offline   Reply With Quote
Old 09-05-2011, 01:10 AM   #7
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I know *I* am a candy a$$. But I didn't know my 3 friends were, too. One on each corner of the short-bed,
steel-floor and we each had only 112.5 lbs?
I was the only one panting...we only moved it about ten feet on two separate occasions.
I would have guessed I had at least 120 lbs on my corner
Clearly a guess on my part.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-05-2011, 08:02 AM   #8
gotchamel
Thanks for the guesses guys, 4 sawhorses sould be enough.My plan is to stand the bed up on end{cab end}with some support and flip it over on the horses.
Old 09-05-2011, 08:31 AM   #9
OJ1988
Just a car guy
OJ1988's Avatar
I took the short bed stepside with wood floor off my truck two weeks ago, me and one other guy, both of us are average joes, had no problem.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-05-2011, 09:40 AM   #10
chopnchaneled
chopnchaneled's Avatar
X's Two, a couple weeks ago.
chopnchaneled is offline   Reply With Quote
Old 09-05-2011, 10:16 AM   #11
teeitup
Just like to part out trucks!!
teeitup's Avatar
I roll long wheel base beds off all the time by myself, they are heavy thats probably why I have a bad back
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 09-05-2011, 12:14 PM   #12
68gmsee
Active Member
68gmsee's Avatar
I've removed it by myself before -with some help from wife.
Remove the bolts and disconnect all electrical wiring. Get two boards either 2X4 or 2X6's that are longer than the bed. I think I used 10' ones for my short bed. Lift one side and have the wife or a buddy) slide it under the bed and do the same for the other side. Place the back end of the boards on two saw horses and slide it backwards.
My guess is the bed weighs around 350 pounds or so.
If you have a cherry picker or tractor, here's what I did recently.
Attached chains under the 2X4's where they intersect with each other and gently lifted while buddy guided it onto two saw horses.
(2X4s fit under the top rail. Boards are not bowed. they just look that way)
68gmsee is offline   Reply With Quote
Old 09-07-2011, 08:48 AM   #13
gotchamel
Well bed is off and on sawhorses,9 of us did it.The weight was not an issue but we inverted the bed w/o putting any weight on the quarter panels while flipping.Very happy with the condition of frame and bed underside.Thanks for the help.
Old 09-07-2011, 09:17 AM   #14
Shyguy
Junior Member
Shyguy's Avatar
Glad you gotter done and the condition of the frame and under the bed was ok.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-07-2011, 09:19 AM   #15
gotchamel
Yes, good condition.Will put up a couple of pics later.Going to clean/degrease today and por 15 is on the way.
Old 09-07-2011, 11:15 AM   #16
dubds10
Stalker Nate
How'd 9 guys move a bed lol I just can't imagine that many fitting around a short bed. 2 guys can flip one all day long. 2 can do a long bed but 4 make it easier. 2 saw horses are enough to hold the weight as well.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 09-07-2011, 12:27 PM   #17
gotchamel
Guess I shoulda called you but the Florida Keys is a long way from BC.{just kidding}
We had 4 guys on each side and rotated it without putting any weight on the ground.I was spotting for the sawhorses,that makes 9.Not sure we could have done it with less{safely}w/o it resting on the ground.Not heavy just awkward.
Old 09-07-2011, 03:08 PM   #18
dubds10
Stalker Nate
Lol I need the vacation but we are just finally getting our summer now, so have to wait till Dec to leave now.
I actually just took off my Grande Sierre bed last month by myself haha. I stripped all the wood out though so it was lighter, but still the 8.5foot bed is huge. Was akwards but I did it without damaging everything. Just have to think carefully about how to do it. Lots of times it's just me working on my trucks so it's always up to me to do it alone.
