09-07-2011, 05:00 PM | #1 |
1969 Custom 30 wrecker
Front to rear brake line question
Is the front to rear brake line 1 piece from the factory? That being from the master to the rear brake hose.
I bought some bulk (25') tubing so I could make it in one piece but want it to be correct so can piece it. This is a 69 C30 by the way. If it's in 2 pieces, where would they be split? Thanks, Bob
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
09-07-2011, 05:15 PM | #2 |
Re: Front to rear brake line question
one piece back to a splitter on the rearend which sends a line laterally to each wheel cylinder.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
09-07-2011, 06:19 PM | #3 |
3pieces/from master to the rear hose
from master cyl to proportion valve//first piece from proportion valve to the front crossmember//second piece from about6"in on the crossmember then accross to pass frame rail back to rearend// number three
09-07-2011, 06:57 PM | #4 |
Mine has drums so no prop valve but it does have the distribution block or whatever it's called (warning light wire goes to it)
I do have the small line from master to that block that is still good condition. So I'll put a union 6 inches from driver side on crossmember. 3 lines it is. Thanks, Bob
