Re: Hooking up two batteries together on my 73 c10?????
Has anyone rigged up a setup where one battery works when the car is shut off...so that even if you run that one down when the engine is off, you can still start the car with the other battery?
That is typically the most common way of setting it up, either with a diode type isolator or with a relay. For example I run the stereo and trailer\camper plugs to the 2nd battery. I can run it down and still start the truck on the main battery. I personally prefer the diode type of isolator, but I'm sure there will be many opinions here as to what is best. In this situation, where you have very high current draw, it may be better for you to have your batteries hooked directly together to provide the amps to run the compressor. The only downside is that the batteries will discharge each other down when the truck is off.
i hate this idea. whats the point of having a seperate battery? u want more consistant voltage and more amperage? run 2 batterys in parallel and call it good. if not ur just drGging abound 70lbs for what?? " if u need it??" an alternator loves 2 batterys. its not harder on it.. its eaiser. less draw=less to recharge.
[QUOTE=cr34t3d_by_d4rkd3n;4887806]i hate this idea. whats the point of having a seperate battery? u want more consistant voltage and more amperage? run 2 batterys in parallel and call it good. if not ur just drGging abound 70lbs for what?? " if u need it??" an alternator loves 2 batterys. its not harder on it.. its eaiser. less draw=less to recharge.[/QUOTE
It comes in handy on trucks with campers. You can run the camper off one battery and still be able to start the truck on the other one. Somebody correct me if I'm wrong, but I think usually the 2nd battery (the one that runs the camper) is a deep cycle battery and the other is just whatever you need to for the vehicle...it can be done that way because of the isolater. I have a camper on my C30 that I want to set up this way when time an money allows. On my diesel burb I need 2 batteries to start the truck and they are wired in parrallell..although in reality I can get away with just one battery...gotta luv the optima red tops.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
With the isolator setup the main battery is not being used so if it goes dead it does not kill the main battery to still be able to start the truck. the isolator separates the batteries until the isolator has power. I have always used this setup for high power add ons to vehicles like a stereo system or airrride. both ways will work but the isolator helps keep the main battery for starting the vehicle.
Posted via Mobile Device |
Isolators work as described but the ones I had (diode type) always failed after about one year of use. More expensive ($100+) isolators are supposed to last longer.
#8 | |
