08-11-2003, 08:58 AM | #1 |
what rear gear in a 72 6cyl 3 on the tree?
Also do you look for a certain option code for positive traction? Or do I need to buy an aftermarket posi.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
08-11-2003, 10:12 AM | #2 |
I don't know about all of them, but my '71 came stock with 3.73 gears. It has the 250 I-6, and 3-on-the-tree. Mine does not have posi-traction. As far as I can tell, my truck was built with zero options, so I would guess the 3.73 rearend was standard. I actually like the setup. The 250 has good low-end torque, and pulls strong from a standing start with the 3-speed. Of course, top speed is somewhat limited, but unless you do a lot of freeway driving, it's really not a problem. I will also add that my gas mileage isn't that great for a 6-cylinder. I probably only get around 17 or 18 mpg. But I doubt that the guys running 350s get that kind of mileage. Also, my truck is a short-fleet bed, so it probably feels spunkier with this drivetrain than a LWB would. In this truck, this drivetrain seems more than adequate, and is a blast to drive. I'm not planning on changing the rearend, or any other part of the drivetrain. However, if it had posi-traction, that would be even better.
08-11-2003, 10:44 AM | #3 |
Thats the Hillbilly way
Resto manuel shows 3:73 stock , with 3:07 and 4:11 optional.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
08-11-2003, 12:42 PM | #4 |
anyone know the option code for posi? I am going to the junk yard!
08-11-2003, 10:02 PM | #5 |
Next!
G80 Positraction (Half tons) G86 No spin G87 Power Lock (What's in my 72 K25) Make sure that's what's actually under the truck though!
GM GM
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
08-11-2003, 10:13 PM | #6 |
they still use that code on some later model stuff I know at least 99 my buddy has a 1 ton crew with a g80
Thanks Kevin
