Old 09-10-2011, 12:50 PM   #3351
Strodder
Daring to be Different
Strodder's Avatar
Re: Project Vitamin C-10
That's true.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 09-10-2011, 10:40 PM   #3352
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by bubba327 View Post
tuned in!!! I wish I was closer .... I'd come over and help!!!
Originally Posted by Strodder View Post
Yeah me too, between all of us, we can really f*ck it up.
That would be great, but would anything get done or would we just talk about doing something.
I can't scratch the paint from here!!!!
So far all I have scratched is the frame.
Not much shop time today, but I'm studing the schematics and planning while watching the race. 13 cautions and just half way thru.
Questions: Is there any reason why I can't keep the relay inside the cab? I know the reason for a relay is the reduce the bigger wires from being in the cab. So that means I need to keep it close to the battery. I just don't want a lot of wires in the engine bay.
Info: I am running a single fan with two terminals.
Fuse panel
Spot #1 to one side of the temp sensor included in the relay package. Then the other wire from the sensor to the yellow wire of the relay.
Spot #2 unsure what to connect there if anything. The only thing I can think of is the ground wire from the fan or the ground from the relay.
Relay
Red wire- to the battery.
Black wire-to chassis ground close to the battery
Green wire- to the AC controller, which will be discussed in a later post
Orange wire- power to the fan with the fan grounded to the chassis.
Let me know if I'm getting close to having it right. I don't want to wire up something I'm not sure of and have to redo it.
Shannon and I went junkin' today and I picked up the connectors for brake lights.
Ok my brain is smoking.
Alan's Classic is offline   Reply With Quote
Old 09-11-2011, 09:26 PM   #3353
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Side question,
You posted this in another thread.
Do you remember what brand support brace you used here?:
Originally Posted by Alan's Classic View Post
Yeah it's me. As far as the tabs went, I just cut them off to length and butt welded it. Did you find the pix you needed? I only had the problem with the hole location on the drivers side.
This might not be the best way to do it, but that is the way it is. I think it will be fine. It has several more welds where I drilled out the old spot welds.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-12-2011, 07:12 AM   #3354
Alan's Classic
Originally Posted by LostMy65 View Post
Side question,
I got them from Goodmark.
Has any body looked at my wiring question 2 post above?
Old 09-12-2011, 10:29 AM   #3355
Strodder
Strodder's Avatar
I would mount the fan relay close to the fan. Not in the cab. Run a temp switch to turn on the fan, or a switch where ever you want.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-12-2011, 08:41 PM   #3356
One of the main ideas/reasons for using a relay is so that you don't have to run the higher amped or volatge wire long distances, especially within ther cab. you can get by with lower rated switches and less chance for shorts or at least more dangerous short.
There's my $.02
Old 09-12-2011, 08:47 PM   #3357
Alan's Classic
Thanks guys, I'm going to repost my question for clarity.
I'm studing the schematics and planning.
My plan
Fuse panel
Relay
Old 09-12-2011, 10:02 PM   #3358
bubba327
HOW long until spring??
bubba327's Avatar
Alan , Just got home, This working for a living screws up my free time
1) the relay is usually located close to the power source and the load as Dennis mentioned. The relay could be hidden be behind the grille off to a side out of view if you wanted.
Keeping the relay close to the load keeps the voltage drop to a minimum with the heavier wires doing the work and then the smaller gauge coil wires running back to the cab to turn things on and off.
2) I think you have the right idea with the plan , I am not sure what you mean by spot 1 and spot 2, Would that be the terminal location from the terminal block(panel connection block)?? I cannot quite make out the terminal numbers on page 1
But with a single fan you would only need the one output from the N.O. relay contacts to the fan motor.
3) use a good grounding method, I like to extend all the ground wires to a common area and ground them together and then to the frame or back to the battery or block.
I have found on old cars and especially trailer lights, most electrical problems are really grounding problems,
Now, looking into the future,, Are you planning to run the high and low beam relays for your headlights??? maybe they all can be hid in a shiny junction box or concealed in the same location behind the grille or headlight bucket area???,
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 09-12-2011, 10:42 PM   #3359
Strodder
Strodder's Avatar
Not to confuse the situation, but I use relays to ground also. I did that with air bag compressors, and worked great. No come backs or melted wires.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-12-2011, 10:44 PM   #3360
Alan's Classic
Thanks Bubba, and yes I was referring to the terminal locations on the fuse block. Sometimes I can't think of the correct words. I guess the relay will have to wait til I get the radiator support mounted for the last time.
So do I need to connect anything to the terminal #2 on the fuse block? It's showing a switch or sending unit to ground. I don't think I need to connect anything there.
Old 09-12-2011, 10:45 PM   #3361
Alan's Classic
Old 09-12-2011, 10:46 PM   #3362
Strodder
Strodder's Avatar
Sorry for that.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-12-2011, 10:48 PM   #3363
Strodder
Strodder's Avatar
Instead of powering the compressor, I use the relay to switch on the ground. Make sense?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-12-2011, 11:43 PM   #3364
Alan's Classic
Old 09-13-2011, 09:38 AM   #3365
lyrikz
PITbut
lyrikz's Avatar
Alan, if you ever have a question about wiring, this guy is a genius with it. I cant tell you how many times i have had a wiring question about air suspension or just my truck in general and he has hit it right on EVERY time.
fixit-p
Awesome guy.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 09-14-2011, 12:37 PM   #3366
65Custom
Lots of progress, looking good!! I'm still not getting notifications on your thread like I used too so I forget to stop by more often
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 09-14-2011, 03:32 PM   #3367
Strodder
Strodder's Avatar
After I commented, I started to think. I'm about to wire up the fan on the 57 Panel I'm working on. Here's American Auto Wire's diagram. I'm going to install the relay close to the fan.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-14-2011, 11:23 PM   #3368
bubba327
bubba327's Avatar
This thread has quit showing up in my mailbox notifications also.
The other threads I am subscribed to are still working... I will have to look into this when I get time
Old 09-14-2011, 11:49 PM   #3369
Strodder
Strodder's Avatar
I made these diagrams to help my customers.
This is how I wire up a compressor for air bags with the relay switching positive power. It can be used for cooling fans also.
This one is with negative switching. I think it works best for higher amp draws. Use a 30/40 amp relay. I never had overheated wires or terminals this way.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-15-2011, 12:12 AM   #3370
Alan's Classic
Just a quick note, I'm not getting all the notifications either from any threads. I think I got two notifications all day from other threads. It's really sporadic.
Old 09-15-2011, 12:19 AM   #3371
Strodder
Strodder's Avatar
I get all the notices. No problem here.
Maybe it your Smart Phone settings?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 09-15-2011, 12:41 AM   #3372
VA72C10
VA72C10
VA72C10's Avatar
who's your email carrier? I'm looking into it...
Old 09-15-2011, 12:49 AM   #3373
FetchMeAPepsi
FetchMeAPepsi's Avatar
You may know it already but for those that don't, you have to visit the forum every time you get a notice from a thread in order to get another notice. You only get one notice from a thread before they require you to visit to reset your notifications.
I think it's one of the most annoying things ever so I just set up cron jobs to visit the forums every few minutes to keep me updated
FetchMeAPepsi is offline   Reply With Quote
Old 09-15-2011, 01:57 AM   #3374
VA72C10
VA72C10
VA72C10's Avatar
I understand the frustration with that and used to feel the same way....but now with close to 5000 subscribed threads I appreciate that I'm not sent an email for every new post
I already get well over a hundred emails a day from this site...it'd be more like 5-600 if i got one for every single post
Old 09-15-2011, 01:19 PM   #3375
Alan's Classic
I use yahoo. I check my build at least once a day and here lately I hardly get any notifications of new post. There are a couple post I get notifications daily and haven't checked that particular thread for some time. Thanks for looking into it.
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
