[><]Sofa King Dirty 4x4[><]
Speedo cable makin noises
How do i go about fixing it because its annoying the hell out of me
00' Chevy Silverado 1500 z71 33"s 3" lift 5-speed Past trucks 85' Chevy C10 Step side 388 stroker 33" bfg a/t's holley 670cfm world product heads 14.80@92mph 92' S10/Tahoe sbc swap |
Another Day, Another Dollar
Re: Speedo cable makin noises
replace it!
i have also heard that you can lubricate the speedo cable with graphite, but i don't really understand how you can get the core out without ruining the cable.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
The core can be pulled and re-lubed if it is in good shape.
You can pull the core either from the tranny or behind the speedo in the dash. *Recommended method is to unhook both ends *Pull the core out *Examine core for any protrusions or kinks. If any are found, replace. *Otherwise, get some sort of cleaner (W-40) and squirt down the tube from behind speedo until it runs clear. *Next, take some white lithium grease and spray it into the palm of one of your hands. *Run the core thru that hand so that it is thoroughly coated. *Carefully run the core back thru the cable *Rehook and test it. *If it still makes noise, the tubing might need replacing or the speedo it self needs some work. Hope this helps.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381 |
