Closed Thread
Old 09-10-2011, 10:33 AM   #3876
Clyde65
Clyde65's Avatar
Re: What did you do to your truck today?
All I did was drive the truck, all week since it has cooled off considerably this last week or so, 85-90 afternoons and 57-63 mornings, weird that when I take the truck to work in this weather, it takes me twice as long to get there...hmmmm
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 09-10-2011, 04:49 PM   #3877
ChrisDollins
ChrisDollins's Avatar
Drove the truck to breakfast with the car guys, then dropped it off at the body shop! Ready to see it shiny again!
Chris
ChrisDollins is offline
Old 09-10-2011, 08:04 PM   #3878
niterider65
niterider65's Avatar
some pics from friday nite and saturday im not done yet looking for torq sprcs on the wheel bearing on the rotor
niterider65 is offline
Old 09-10-2011, 08:21 PM   #3879
chemlab
chemlab's Avatar
rolled mine out and hosed it off
chemlab is offline
Old 09-10-2011, 08:50 PM   #3880
Turkey
Turkey's Avatar
finally got all the trim holes slicked off. More primer tomorrow. Drove it around a little and got a pic.
Turkey is offline
Old 09-11-2011, 01:09 AM   #3881
niterider65
:just a few more dics are on . now i have to run a spacer on the frony to keep
the wheel from rubbing the caliper great sounds like new wheels.. finished the steering link just need to get the power steering box and brackets and stuff..
Old 09-12-2011, 02:42 PM   #3882
steverino66
sanded the cab interior… sanded some more (note non-OSHA-approved platform for sanding ceiling)
steverino66 is offline
Old 09-12-2011, 02:52 PM   #3883
chad64chevy
chad64chevy's Avatar
well saturday i repaired my driver fender, and today i started on the passenger fender
chad64chevy is offline
Old 09-12-2011, 02:55 PM   #3884
chad64chevy
a few more pictures
Old 09-12-2011, 03:33 PM   #3885
el_bole
Nice body work!!!
Well my task this week included less finesse than body work LOL...
Used a hand grinder to cut transmission cross member from my '61, helped tons in getting the motor out ....Needed the rm any way to put my 350 tranny in , oh yeah and of course I removed a the clip to do all this detail work
el_bole
el_bole is offline
Old 09-12-2011, 04:02 PM   #3886
chad64chevy
thanks el bole, i was shocked myself that i didnt screw it up!!
Old 09-13-2011, 01:52 AM   #3887
pdxhall
pdxhall's Avatar
I finished up my rear suspension today except for the track bar which is on it's way. I still have to order and install a new center crossmember to raise the trailing arms but at least it's back on 4 wheels for now. Brakes are probably next. I pushed it out of the garage and washed it up a bit before starting the next phase. Here are a few pics. I also borrowed member Frizzle Fry's idea for relocating the rear shocks. It worked out great. Thanks Friz for the idea.
pdxhall is offline
Old 09-13-2011, 01:59 AM   #3888
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Your truck is really looking nice.
The cab appears to be in nice shape.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline
Old 09-13-2011, 02:24 AM   #3889
pdxhall
pdxhall's Avatar
Yeah I got pretty lucky on this truck. Minimal rust in the front corners of the floors and that's about it except for the passenger side vent assembly or whatever it's called. It's the outer part that the bottoms all pick up crud and then rust out except mine is also rusted at the top. I need a whole new one when I get to the point of rust repair. If you remember I asked obout that parts cab you picked up. But I"m a ways off from needing one, but it's on the list. I kinda grab stuff as I go when I find a great price.
pdxhall is offline
Old 09-13-2011, 02:44 AM   #3890
losthope
losthope's Avatar
Originally Posted by el_bole View Post
Nice body work!!!
el_bole
im interested in the geen fender and headlight in the bottom right corner of the last picture,any pics??
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 09-13-2011, 12:38 PM   #3891
Frizzle Fry
Frizzle Fry's Avatar
Looks better than mine You're gonna love the high speed stability that mod adds. Nice work!
Frizzle Fry is offline
Old 09-13-2011, 12:44 PM   #3892
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Cage done...............check
Seats mounted.........check
Slowly making progress.....
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 09-13-2011, 03:32 PM   #3893
LostMy65
LostMy65's Avatar
I will be sanding my ceiling while I have the cab rolled over on its back.
LostMy65 is offline
Old 09-13-2011, 05:06 PM   #3894
steverino66
Yeah, I had the cab on its back earlier and, despite being VERY careful, managed to slightly damage the sheetmetal on those tricky edge ridges; also kept feeling like I might put a foot through the back window stumbling around in there!
That being said, I recently realized I STILL have to rotate it back in order to paint with the gravity-fed HVLP sprayer. I think I'll try suspending the cab next time.
Old 09-13-2011, 06:02 PM   #3895
el_bole
Losthope,
Thats funny u r interested in the fender and headlight! I just officially inherited that car that the fender is attached to LOL...It was my Dad's '55 Olds, Delta 88 to be more specific....Asking $6,000,If I had the resources I'd rat rod it out and put some bags on it but thats what I got my 61' for Right?. Here's a couple pics...
el_bole is offline
Old 09-13-2011, 06:32 PM   #3896
losthope
losthope's Avatar
looks nice !! its a four door id leave it the way it is besides lowering it and drive the wheels off it, thanks for the pics love them olds!!!!!
Timmy D.
losthope is offline
Old 09-13-2011, 06:43 PM   #3897
Slow Build
Slow Build's Avatar
I replaced my stock steering wheel with a Chevy Lumina wheel that I got at the junkyard for $20. It's much more comfortable for me and doesn't look too out of place. I can't really see the speedo that well because it's a smaller diameter and thicker grip but that's no big deal. Right?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 09-13-2011, 06:45 PM   #3898
Slow Build
Slow Build's Avatar
Forgot the picture.
Past GM Trucks:
Old 09-13-2011, 08:45 PM   #3899
Rich 5150 69
Rich 5150 69's Avatar
I`m sorry guys, I just hate to have my down to do anything I like driving it to much, lord knows it needs a lot of work....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 09-13-2011, 08:52 PM   #3900
glendale
glendale's Avatar
i would just swap the body to a two door body how hard could that be?
glendale is offline
Closed Thread
