Old 09-13-2011, 09:53 AM   #2051
Hurst28
Re: 67 cheby's Dropmember build thread
What is the backspacing on the rear wheels? I really like how close the wheel/tire is to the bedside. Really looks clean that way.
Hurst28 is offline   Reply With Quote
Old 09-13-2011, 09:58 AM   #2052
67cheby
67cheby
67cheby's Avatar
the back wheels are 22x10's with 7 1/2 inches of backspacing, but i am running a billet spacer with a 69 up rearend , i couldnt see spending the BIG BUCKS....that it takes to get these kind of wheels custom made to exactly what i wanted so i made these work with the setup i have , bought them on this board in the for sale section...THANKS VA72c10 once again, I LOVE my wheels
67cheby is offline   Reply With Quote
Old 09-13-2011, 10:40 AM   #2053
oldman3
oldman3's Avatar
I take off one day and you add two pages to the build, way to go. Love the tubs and the truck looks great, nice job.....Jim
oldman3 is offline   Reply With Quote
Old 09-13-2011, 10:44 AM   #2054
67cheby
67cheby
67cheby's Avatar
trying to make up for 6 months of adding NOTHING !!
Old 09-14-2011, 09:24 AM   #2055
67cheby
67cheby
67cheby's Avatar
did i mention how much i love having my truck at home ..... only had about 1 hour to work on it last night but i started with the used Painless wiring i got from a board member, and stripped all of the tape and loom off it, stripped the wires i didnt need from the engine compartment, and started temporarily routing the wires so i can figure out lengths and routing paths !! It was great if i can get just 1 hour of stuff done a day ...it is MOVING FORWARD !!
Old 09-14-2011, 10:37 AM   #2056
68 TT
Still plays with trucks
68 TT's Avatar
What do you have in mind for accessing the anchor bolt for the harness connector? Maybe a tip down access panel so you can get at the anchor bolt but still have it out of sight when not needed.
The panel could cover the whole vent opening to seal it off too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-14-2011, 11:32 AM   #2057
67cheby
67cheby
67cheby's Avatar
yes i am building a panel that bolts in and out of the vent hole, and then covering in with , custom made speaker kick panels
Old 09-14-2011, 02:04 PM   #2058
68 TT
68 TT's Avatar
That should work nice.
When are you going to drop the drivetrain in there?
Old 09-14-2011, 09:13 PM   #2059
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good!
Glad to see it's back home for some regular (ahem,... daily) updates.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-15-2011, 05:23 PM   #2060
67cheby
67cheby
67cheby's Avatar
LOL...yep, gonna get all of my wiring routed for mock up !!
Old 09-15-2011, 07:17 PM   #2061
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Please tell me your gonna run that wire under the core support????
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-15-2011, 09:58 PM   #2062
67cheby
67cheby
67cheby's Avatar
no it will run through it, completely concealed !! all wire except for the ones running to the absolute necessary stuff will be hidden, along with ac and heater hoses
Old 09-16-2011, 08:56 AM   #2063
FRENCHBLUE72
PROJECT 7DEUCE
Hell yes I was hoping you were gonna say that..
MEMBER #6377
Project "7DEUCE"
Old 09-16-2011, 09:11 AM   #2064
67cheby
67cheby
67cheby's Avatar
yeterday i stopped by a swap meet the first pic is what i couldnt pass up for $10 buckaroos, mocking up my vintage air so i can figure out where to put my computer brain, and where to run my fuel injection wiring out of the firewall (i am thinking in the middle right behind the distributor), then got the box put back in working on getting everything set so i can start stretching the fleece on it to make all of the contours ! oh brought the painless wiring to work with me today to start cleaning it up and checking all of the wires on it !
Old 09-16-2011, 12:08 PM   #2065
67cheby
67cheby
67cheby's Avatar
i am thinking about going to GoodGuys on Oct 1st if i can get a couple orders for SLOSH TUBZ, to take and deliver, give me a shout if anyone is interested ! FREE DELIVERY !!
Old 09-16-2011, 12:45 PM   #2066
68 TT
68 TT's Avatar
Nice score on the valve covers.
The speaker box looks great.
Old 09-16-2011, 01:08 PM   #2067
67cheby
67cheby
67cheby's Avatar
thanks..i just cant pass them up i love these valve covers...the box will look alot better once i start stretching the fleece on it , it will really contour nicely then !!
Old 09-16-2011, 01:12 PM   #2068
RocketKing
RocketKing's Avatar
How did the speaker box "bend" around the corners? I can't really see how you did that from the pic.
BTW what engine are you looking putting in?
Rex
RocketKing is offline   Reply With Quote
Old 09-16-2011, 01:17 PM   #2069
67cheby
67cheby
67cheby's Avatar
it hasnt really "bent" yet the fleece strecthed around the corner and then fiberglassed is what will make the bend This is a pic of the end of the box then i added a piece of 1/4 inch panel to fill the cab corner hole and stretch the fleece to and that will make the curve
Old 09-16-2011, 01:20 PM   #2070
67cheby
67cheby
67cheby's Avatar
my engine is a throttle body injected 350 with, eldelbrock tbi intake and holley throttle body, nothing wild just a good dependable FUEL INJECTED cruiser , with 700r4 I think this is the last pic i have with the motor still in it
Old 09-16-2011, 06:58 PM   #2071
68 TT
68 TT's Avatar
Nice reliable daily driver of an engine & trans. Same stuff I have going into my 69 K10 project. I have had a few TBI vehicles and they have all done pretty well reliability wise. Good choice to keep things on a realistic budget too.
Old 09-16-2011, 07:54 PM   #2072
Dinos63
chevy only
Dinos63's Avatar
it always nice to get your truck home.... and just go out and look at... for hours at a time killer work kat
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 09-16-2011, 09:53 PM   #2073
67cheby
67cheby
67cheby's Avatar
my second favorite thing about it is , it still looks like a stock motor !! somewhat original, i have a powdercoated black March serpentine pulley setup ready to install, running the factory style valve covers and breather, cant wait to get some paint on my motor and get it all put together !! i have everything for it just stripped it back down for a better paint job !!
Old 09-16-2011, 09:54 PM   #2074
67cheby
67cheby
67cheby's Avatar
LOL...yep been doing that ALOT !! the most heard statement at my house lately WHEN ARE YOU COMING IN ??? UMMMMM in just a minute babe !!
Old 09-16-2011, 11:41 PM   #2075
Dinos63
chevy only
Dinos63's Avatar
been there
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
