Old 09-13-2011, 10:58 PM   #1
Slammed50
Radiator question
I have a question about the size of a stock 63-66 V8 radiator. I'm trying to find an aluminum replacement but am unsure about the size of the original one. If I could get some measurements off a stock one from top to bottom and side to side, including the tanks it would be a big help. Thanks.
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 09-14-2011, 09:38 AM   #2
Clyde65
Clyde65's Avatar
Re: Radiator question
this is the one I bought, mine came with dual electric fans also. direct fit for a v8 radiator replacement.
http://cgi.ebay.com/ebaymotors/1963-...item25677b43a4
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-14-2011, 01:39 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Radiator question
For 1/2 AND 3/4 Ton trucks that came originally with a 292 L-6 or V-8, 17 3/8 X 24 3/4" X 2"
63-66 TRUCK V8 ALUMINUM RADIATOR WITH AUTOMATIC TRANS
http://www.classicindustries.com/tru...l80430and.html
63-66 Chevy P/U V8 A/T Alm Rad Dimensions 17 1/4 x 25 1/2" x 2 5/8" 4 ROW Reproduction radiators install exactly like original! Unlike aftermarket replacements, our radiators mount correctly using original style brackets. Aftermarket radiators are usually not suited for installation to maintain originality. The original appearance is important to your restoration. Beware of replacement radiators which do not have the correct brackets for mounting. Each Classic radiator is equipped with a new tank andcore. Not a rebuilt! Comes complete with original style mounting brackets attached and installs as original to the radiator support. The fan shroud must be replaced if your are installing a radiator for air conditioned models on a vehicle which did not include factory air. This helps to maintain a correct fit and sufficient air flow to the engine. No Exchange Required! No Core Charge! Note: Fan shrouds, fan shroud brackets, radiator petcock, radiator cap and shroud mounting clips are available separately. Due to dimensional differences, fan shrouds are not interchangeable between air conditioned models and non air conditioned models.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-14-2011, 02:42 PM   #4
Slammed50
Thanks 1bad.
Clyde, how much was your radiator with the fans and shroud assembly? Did if have an internal tranny cooler as well?
Old 09-14-2011, 03:02 PM   #5
Clyde65
Clyde65's Avatar
this is actually who from/what i got, it had 2 12" electric fans that came with it, no shroud but your original will work. yes it had the tranny cooler in it. I also put on an external just because I am an anal S.O.B. I think it was around $229 or so. mine is a 3 core/row
http://www.reliableradiator.com/serv...sh-1966/Detail
Clyde65
Rebuild of Clyde
support our troops!
