GoatLube Experss
![]() Join Date: Oct 2009
air bags on a car hauler
been think'n I wanna do a heavy duty 2 link on my car hauler so I can squat the rear to assist in load'd my MonteCarlo ,also later on I can rework the bed with no suspension crap behind the axle.
I would go with a bag over axle set up, what bag's would handle the truck plus 3000lbs ?
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#2 | |
Conversion Truck Addicted
Re: air bags on a car hauler
semi trucks uses airbags so i think a set of the could de the bag over axle
also Monster trucks back in the 80s early 90s used airbags and some still do but its very little used because of limited travel and thats 12000lbs landing on concrete sometimes
Thomas Quote:
What a great idea! sorry i dont have the info you need but i also have seen big semis and a roll back tow truck with bags over the axles. I would run that question by the bag supplier.
keep us posted sounds like a great project!
51 Chevy 3100 Deluxe Cab(SOLD) ![]() 65 **stang 6cyl 70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD]) 72 C10 Short Bed Fleetside 73 Blazer 2WD Catalina Blue White Top(Needs Love) 73 Blazer 2WD Work in progress LT1/4L60E 83 Grand National (SOLD) 94 Blazer K1500 Silverado (SOLD) 96 Impala SS All original (NEXT IN LINE 2 B SOLD) 99 Tahoe 2DR, 2WD ![]() |
Maxey makes this car hauler, might give you and idea...
![]() http://www.maxeytrailers.com/trailer...ls.php?tid=113 |
Dang! thats pretty sweet!
contact local tow truck companies and find the names of local shops that equip their trucks. I know our local supplier can supply air bag kits for 1 tons up to 25 tons trucks. If you can find your local jerr dan dealer/installer ill bet they can help you.
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case |
for vertical clearance and weight capacity purposes, it may be better to put the bag behind the axle with pivot point well in front of the axle.
'76 C10 "BIG10" SWB 454/400 Mostly Stock. |
