Old 09-14-2011, 06:20 PM   #1
swammie911
Lowering Help
I know there is a lot of talks on the forum regarding lowering but I just couldn;t find the specific answers I was looking for. I have a 72 SWB with all four corners having the stock coil springs. I would like to lower it. I am going for a Stock meets custom look and am currently planning to put some 17" Cragar 8s on all for corners. I would like to know your opinions for lowering heights. I would like to stick with a springs only approach and maintain stock shock size. I'm thinking a 1/3 drop or a 2/4? Your input would be greatly appreciated!
Thanks. This forum is great.
swammie911 is offline   Reply With Quote
Old 09-14-2011, 11:30 PM   #2
SCOTI
SCOTI's Avatar
Re: Lowering Help
A 1/3 drop isn't worth the effort IMO (1" drop from stock is basically stock coils after 30+ years of regular use). A 2/4 drop would be noticed & do-able w/just coils & stock shocks.
There's nothing wrong w/just doing drop coils. But, a 2.5/4 drop w/spindles & your current coils in the front plus 1-1.5" lowering blocks in the rear w/a 2-3" drop spring & the ride doesn't change @ all.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-14-2011, 11:43 PM   #3
jserrato714
jserrato714's Avatar
Re: Lowering Help
Amen Scott! I personally think the lower the better...On my old 68 I did 2 1/2 drop spindels with a 1" drop coil and the the rear was a flip kit cuz I had leaf springs and it looked tuff. The ride was great...I also use new stock shocks all around which I bought at auto zone. My wheels were 15s. Truck handled nice and looked good.. If ya you want a 1 " drop then just leave it like it is ...after so many years your probably at 1 1/2 sitting as it is. Good luck
jserrato714 is offline   Reply With Quote
Old 09-15-2011, 12:04 AM   #4
67_SS396
Re: Lowering Help
This was mine with a three front, two rear, all springs. It was a BB, so I used BB springs.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 09-15-2011, 11:46 AM   #5
tubbedII
needs more $$$
tubbedII's Avatar
Re: Lowering Help
I too am a fan of the lower the better. I think tire size will play a big role in how low you "should" go. I like the look of minimal wheel gap from tire to fender. With 17's, this probably means a 3/5 or 4/6 drop...but that's my opinion.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-16-2011, 12:19 PM   #6
kieth
kieth's Avatar
Re: Lowering Help
I currently have 6 cylinder front coil springs up front and am running 17" cragars (9" wide) I am putting on 2.5" drop spindles today, will post pictures after I am finished,,,,,,,,
ps I am also running a 91 burb front crossmember and a arms so I am a little wider in the front than you.......I am concerned about the additional width the spindle will add to my clearance....will see what happens....Kieth
I also have air bags on the rear and no notch, but I have a notch on the way but thought I would wait so see how things looked overall and then put the notch in to improve the amount of travel the suspension has after dropping the front.......
http://kieth.smugmug.com/Trucks/66-G...7_nS2QZT6-A-LB
kieth is offline   Reply With Quote
Old 09-16-2011, 12:26 PM   #7
SCOTI
SCOTI's Avatar
Re: Lowering Help
71-87 trucks & thru 91 Burbs/crew-cabs have the same track width w/disc brakes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
