Old 09-17-2011, 07:59 AM   #1
pvienneau
pvienneau's Avatar
How close is your fan to your radiator
The fan on my 49 chevy 216 is a sheet of paper away from the radiator. Is this how the fans were in these old trucks? How close is your fan? And how close should it be?
Pat
pvienneau is offline   Reply With Quote
Old 09-17-2011, 11:23 AM   #2
Denee007
Denee007's Avatar
Re: How close is your fan to your radiator
Wow! a sheet of paper close? That's close! logically in my little but significant brain~ seems like close would be good as long at it's not ever touching and a fan shroud could be incorporated?
This on my '59 Apache, I had my plastic replica engine in place trying to visualize the same thing your talking about. Here my HEI distributor is .5" away from the firewall, but haven't figured out the tilt of the engine yet~ eh, a ways off yet.
a good question!
dne'
Denee007 is offline   Reply With Quote
Old 09-17-2011, 04:09 PM   #3
Coupeguy2001
Coupeguy2001's Avatar
used to be 1 1/2" stock, but now since I installed the serpentine belt, installed the subframe, it is 8 inches away, time for a spacer and a shroud.
Coupeguy2001 is offline   Reply With Quote
Old 09-17-2011, 05:15 PM   #4
Wheelie
If your running a shroud it needs to be about halfway into the shroud. Otherwise I would keep it about half inch away to reduce buffeting and striking against the radiator. A sheet of paper is too close. The only thing I use a sheet of paper for testing for flow by checking to see if it can hold up the paper by sticking it on the front of the radiator. If the paper holds its good flow!
Wheelie is offline   Reply With Quote
Old 09-17-2011, 08:13 PM   #5
mknittle
mknittle's Avatar
That,s way too close!! 1/2 inch would be close for a street car
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-18-2011, 12:27 AM   #6
Maximus
Maximus's Avatar
Mine was about as close as yours, I used it on another project and opted for an electric fan.
Maximus is offline   Reply With Quote
Old 09-18-2011, 07:30 AM   #7
pvienneau
pvienneau's Avatar
OK, it looks like a couple fan blades have been bent out of original shape. 2 look correct and 2 look close to the radiator. Is it OK to just bend the others away from the radiator to 1/2 inch back?
Pat
Old 09-18-2011, 07:43 AM   #8
entourageguy
Yellow truck club
entourageguy's Avatar
I would not be bending fan blades. Abit of stress on that metal and things could break and start flying.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 09-18-2011, 10:22 AM   #9
mknittle
mknittle's Avatar
I have seen hoods that fan blades have gone through! I wouldn't want to be in the way of that!
Mark
My GMC build.
Old 09-18-2011, 07:47 PM   #10
Dan Bowles
AD Addict
Fans are cheaper than hoods and radiators.
Dan Bowles is offline   Reply With Quote
Old 09-18-2011, 09:25 PM   #11
Dan in Pasadena
Dan in Pasadena's Avatar
...and (human) body parts!
Dan in Pasadena is offline   Reply With Quote
Old 09-19-2011, 05:56 PM   #12
pvienneau
pvienneau's Avatar
OK, no benmding the fan. Just came back from a garage that works on old trucks and the mechanic says everything looks fine but if I wanted I could move the radiator forward a quarter to half inch by installing on the front side of the bracket with minimal mod.
Pat
Old 09-20-2011, 07:20 PM   #13
Nordic
Nordic's Avatar
Mine is about 3 inches from the radiator and will be about half way inside the shroud . Right now the shroud is deep it hits the alternator it is next to be cut down.
Nordic is offline   Reply With Quote
Old 06-10-2012, 02:34 PM   #14
GuyO
GuyO's Avatar
Hi, a sheet of paper width away from your raditor is way too close IMO and the slightest mechanical malfunction could be extremely costly! If I am not mistaken it appears in your picture you have a "long" water pump which is about 1 1/2" longer than a "short" pump. If you have a choice the short pump would get you better clearance and still cool but also allow the engine to move and flex under different loads. Generally the fan should extend well into the shroud, some say "half way in" and be "approximately 1 1/2" away" from the radiator. I have seen them as far as 7" away so watch your gauge and see! G.
GuyO is offline   Reply With Quote
Old 06-10-2012, 02:43 PM   #15
B_Hix
B_Hix's Avatar
Mine is about 1.5". I'm using a thick Mustang II 4-row radiator with no spacer.
No room for a electric puller fan, but I'm thinking I may add a pusher fan. The truck is fine except in traffic on hot days - it's got up to 205 degrees on the worst day I have had.
B_Hix is offline   Reply With Quote
