Closed Thread
Old 09-15-2011, 01:13 AM   #2801
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: What did you do to your truck today!
Painted out the "yellow tag" on the Vintage Air drier (showed thru the grille);
90% installed on the new grille (How the Hell do those square nylon expanding clips work?...I never can get them to work without shaving them);
Installed sound deadner under the hood. Pulled and painted the plate for the "male" side of the hood latch;
Installed "female side" of the hood latch on the rad core support and grille and grille center bracket.
Light day. No pics today. Nothin' really to show.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-15-2011, 08:46 AM   #2802
Originally Posted by RossRinSD View Post
My fuggin compresser finally died. Its been having some issues, takes forever to get pressure over 100 PSI. Its a decent Craftsman I purchased almost 15 years ago. I let a buddy borrow it/stored it as his house while I was moving about 2 years ago. When I got it back, the little plastic air filter holder was broken. I didn't worry too much about it at the time...
FFWD to today when the thing won't get up over 60 PSI. I pulled the head, and found where a piece of the plastic air filter holder had gotten in, screwed up the ring on the piston, and then the piston scuffed the hell out of the bore sleeve.
What sucks even more is I saved up for a plasma cutter which will be delivered tomorrow, but with no compressor, I won't get to use it.
Anybody know where I can buy a rebuild kit for a Craftsman compressor? A new sleeve and piston ring should get me by for the next 15 years...
And people wonder why I hate loaning my stuff out...
I did however get my radiator overflow bottle installed. It worked wonderfully, except I didn't fill it enough, the engine warmed up and purged all this air out, and maybe a cup or two of coolant into the resevoir. Once it cooled back down, it sucked the resevoir dry, and probably a bunch of air.
My old compressor died too, but just from age. I replaced the compressor motor with one I picked up from Harbor Freight. 2 years and it is still running strong. In my case it was about the same price as rebuilding my old one.
Palf70Step is offline
Old 09-15-2011, 12:18 PM   #2803
Lippyp
English Chevy Owner
Lippyp's Avatar
Woo Hoo she runs!
See my build thread for more details!
http://67-72chevytrucks.com/vboard/s...05#post4900805
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline
Old 09-15-2011, 10:03 PM   #2804
Autometer
Autometer's Avatar
Dyno'ed the 406 for it.
'05 Silverado
'02 Avalanche
'85 C10
'71 C10
'51 3100
Autometer is offline
Old 09-15-2011, 10:48 PM   #2805
into69z
"brand new second-hand"
into69z's Avatar
would you share what's in it? like heads,cam,pistons/cp ratio carb size...sure is impressive
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline
Old 09-15-2011, 11:32 PM   #2806
crazy longhorn
Fabricate till you "puke"
I licked the sticker, stuck it on the plate.....then I got on my Harley & rode crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline
Old 09-15-2011, 11:54 PM   #2807
Autometer
Autometer's Avatar
Trick flow 2.100/1.6. Custom Isky solid roller 600 lift 250@.050, Custom JE pistons for the wedge heads. Compstar crank. 11.75:1 and 750 DP. I ran it on supreme with 30* timing.
'05 Silverado
'02 Avalanche
'85 C10
'71 C10
'51 3100
Old 09-16-2011, 01:48 AM   #2808
johntom
johntom's Avatar
Sanded the bedsides and hammered out some dents. I get to put the bed back together tomorrow though!!
68 short fleet cst
71 custom deluxe lwb RIP (parts truck now)
71 Datsun 510
49 GMC 150 (waiting for me for the past 15 years)
johntom is offline
Old 09-16-2011, 10:47 PM   #2809
laplander
Didn't get anything done, but I did manage to annoy the UPS guy with these pieces arriving all at once. LOL. Now to get the engine finished up.....
laplander is offline
Old 09-17-2011, 08:20 AM   #2810
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
MMMMMMMMMMM BLOWER..... Very nice...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 09-17-2011, 11:32 PM   #2811
red71c10
The Red Menace
red71c10's Avatar
I bought a used tailgate to replace mine. It has some surface rust I'll have to clean up, but at least it's not rusted through like the old one is.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline
Old 09-18-2011, 12:26 AM   #2812
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
went out and practice leaving the line with transbrake and made some adjustments to my 4 link ,its hooking up real nice now .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline
Old 09-18-2011, 01:44 AM   #2813
dukcaln
dukcaln's Avatar
nothing major....finally adjusted the head lights, replaced two bulbs and adjusted the carb, best I could do without a vacuum gauge.... running pretty good. tomorrow will check the timing again....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline
Old 09-18-2011, 09:30 AM   #2814
FRENCHBLUE72
PROJECT 7DEUCE
Painted more parts with satin clean really diggin the look of this stuff..
MEMBER #6377
Project "7DEUCE"
Old 09-18-2011, 12:47 PM   #2815
dukcaln
dukcaln's Avatar
post a pic of something painted....
SOLD 1972 chevy c10
dukcaln is offline
Old 09-18-2011, 11:05 PM   #2816
ryanroo
ryanroo's Avatar
removed a bit more of the old and crusty. not alot of time for the truck this weekend. had to dodge rainstorms while landscaping and finish speading gravel for the jeep's new parking spot. hopefully i will be ready to start cleaning and boxing the frame in front of the cab in the next few weeks.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline
Old 09-19-2011, 12:12 AM   #2817
Shyguy
Junior Member
Shyguy's Avatar
Today may son and I finished welding in all the patch panels and outer rockers on the cab for my '67 swb stepper. I probably should say my son is the welder while I am the patch panel fabricator.
After we got stuff cleaned up we looked over the cab and marked all dents that we need to fix and discussed what to do next Sunday. You see we only work on my truck on Sundays, my son and his family and me.
Since I am a novice at sheet metal work I have learned quite a bit while working on the cab beside how to make patch panels.
Here are few that many of you may already know about. Don't use a 4.5 inch angle grinder with a cut-off wheel or grinding disk without wearing leather gloves or a face shield. The first day the grinder got away from me and nicked both of my fore fingers and the sparks pitted my glasses. Here is another one be ever vigilant about where the sparks are going, set my shirt on fire also the first day.
Now when I use the grinder I wear leather gloves, a face shield and no flammable shirt.
I have become pretty good at making patch panels from the sheet metal from an old hood.
Hopefully I will learn more next Sunday.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 09-19-2011, 12:13 AM   #2818
crazymason
Picked up a 71 GMC 2500 for $1600 with the intention of it being a parts truck for my 71 C20. Upon closer inspection this "parts" truck is more rust free than my Chevy, and all numbers matching as well. Can't bring myself to take it apart yet.....
Not sure what to do
crazymason is offline
Old 09-19-2011, 01:48 AM   #2819
red71c10
The Red Menace
red71c10's Avatar
Not sure what to do
To quote Boris Badenov: "If you didn't done it yet, don't did it!!!!!!!
red71c10 is offline
Old 09-19-2011, 06:49 AM   #2820
Bennett68C10
Bennett68C10's Avatar
Continued working on my doors, removed the outer skin from the passenger door and started installing new skin.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 09-21-2011, 12:11 AM   #2821
Tmwoodall
Installed this. This is just a dress rehearsal, push rods get here tomorrow then I can bolt down the intake, carb, etc.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline
Old 09-21-2011, 12:21 AM   #2822
bc gman
71 bb longhorn
After the carb was rebuilt a few months ago the truck still wasn't running right so the guy that did it for me came to the conclusion that the gas tank was the culprit so out it came today and hopefully be back in tomorrow (Wish I would of changed when the truck was in pieces) I thought it was good.
71 2500 Gmc longhorn with a 402 turbo 400.
09 F150 Supercrew 4x4
05 Mazda 6 sport
accept that somedays you are the statue
and somedays you are the pigeon.
bc gman is offline
Old 09-21-2011, 08:09 PM   #2823
FRENCHBLUE72
PROJECT 7DEUCE
Heres one of the pics I actually remembers to shoot of my satin paint job for who ever asked..
MEMBER #6377
Project "7DEUCE"
Old 09-21-2011, 08:21 PM   #2824
cparman
sharp as a marble
I drove it to work today! 72 Blazer 2WD. had been neglecting it for more than a month, and she responded as expected. Cranked right up!
cparman is offline
Old 09-21-2011, 09:02 PM   #2825
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today!
Installed the shock relocator and had to lose the rear sway bar.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Closed Thread
