#32 |
Old member
Just another thought here to.
I have ran into this before. The stock gauge in our model trucks may not give a good reading if the temp senor is for that motor and not our year motors. You may want to check that. When I put my TPI motor in the truck it read high all the time. I had to get the sendor out of the old block and install it. It reads just like it should have then. This may have been covered. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
| Bookmarks |
| Tags |
| cooling system, fan, overheating, radiator |
