09-04-2011, 08:12 PM | #1 |
1971 Bench Seat Question
Bought a '71 3/4 ton 4x4 Chevy a few months back and recently replaced the foam in the bench seat. Now the seat seems too tall. Ordered it from LMC. Any one out there have a similar problem and what's the solution - want to keep it original. BTW found the build sheet in the springs on the back of the seat when I took it out!
VRS |
09-18-2011, 03:44 PM | #2 |
Re: 1971 Bench Seat Question
Bump ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-18-2011, 05:32 PM | #3 |
Not sure what this has to do with my question
09-18-2011, 05:37 PM | #4 |
He was simply "bumping" it to the top of the thread list for you so more people would see it and you would hopefully get an answer. It's actually a nice thing!
09-18-2011, 06:33 PM | #5 |
Thanks didn't mean to appear rude, was just wondering.
09-18-2011, 07:22 PM | #6 |
Junior Member
Yep, it takes a little while to catch onto a few terms on here, but it sure is a lot easier than trying to figure out textese
Bump and ttt both mean to take your question back to the top of the thread hoping someone will be able to answer it. You are lucky to find the build sheet, I guess I have worked on at lest 6 of these old trucks and have never found one. I am sorry I don't have an anser to your question though.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-18-2011, 07:24 PM | #7 |
Moderator
Your seat now sits like it did 40 years ago when it was new. I can't think of anything to squash it down.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-18-2011, 07:31 PM | #8 |
It's just new foam needing to be broke in.
1969 Chevy c20(Miss Hackjob) |
09-18-2011, 08:18 PM | #9 |
thx
09-18-2011, 08:28 PM | #10 |
I don't really think it sat that way 40 years ago, you can't push in the clutch without your leg getting smashed by the steering wheel and if your over 5 ft 8 in, your head is gonna touch the roof - my son has to sit with his head tilted over when he's in it. The foam is correct height of 7 inches, but has no give. It's like sittin on a granite slab.
09-18-2011, 08:34 PM | #11 |
Moderator
I just had my seats redone too and they sit higher than they did before.
09-18-2011, 09:45 PM | #12 |
The Older Generation
I'm shooting from the hip here... Some seats were "Full Foam Seats" and some were not. If you put new foam on a seat that was not a full foam seat I think it would set too high. Also there were two styles of seat tracks and one style is higher than than the other. It sounds like you have a wrong combination going on somehow... Just my 2¢ worth LockDoc
09-18-2011, 10:19 PM | #13 |
^^^ that's a good thought, maybe check your spec sheet in your cubby if its the original seat. Last night checked mine an it said full foam seat. Maybe the new foam is stiffer.
09-19-2011, 01:54 AM | #14 |
The Red Menace
If it's a base Custom truck then it should have come without a full foam seat. That was something you got for stepping up to the Custom Deluxe or Cheyenne.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
09-19-2011, 10:51 AM | #15 |
LockDoc is correct.
09-19-2011, 11:09 AM | #16 |
Mine was just like that after I had it re-done five years ago - it's sits a little lower now. The more you SIT on it, the better it will get. I can see better over the B I G steering wheel this way though !!! . . . . |
09-19-2011, 12:50 PM | #17 | |
09-19-2011, 01:09 PM | #18 |
Active Member
My 68 and 69 were both spring seats with thin foam. Check your seat to see if has the springs on it or recessed for full foam.
The thin foam was not available last time I looked (been a while) but seems to me a good upholstery shop should be able to shave foam to any size you want. Problems is the bottom cover may not fit properly and would have to be redone. (My guess.....) Last edited by 68gmsee; 09-19-2011 at 02:37 PM. |
09-19-2011, 02:40 PM | #19 |
Put some weights on it
09-19-2011, 03:35 PM | #20 |
~Rest In Peace~
mine too but my big butt keeps it down some what
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
