Old 09-18-2011, 08:07 PM   #1
67Mach1
67Mach1's Avatar
Seat Belt Removal
I'm trying to pull some seat belts out of my parts suburban... Any ponters on how to get the rubber covers off?
Who could I send out the seat belts to re-web them? THese are faded and some are frayed a bit.
See photos?
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 09-18-2011, 08:28 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Seat Belt Removal
To remove the shoulder harness cover you need to "feed" the seatbelt back into it and pull the cover up 90 degrees to expose the bolt. The floor boot needs to be worked back and forth and pulled back over the seatbelts.
Snake Oyl I believe re-webs seatbelts
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-19-2011, 02:32 AM   #3
68chevycst
68chevycst's Avatar
I wish I had those shoulder harness seat belts for my suburban!
68 Chevy CST Short Bed, 70 Chevy CST Short Bed, 70 Chevy Short Bed 4X4, 72 Chevy Cheyenne Super 4X4, 72 GMC 1/2 Ton 4x4 Sierra Grande, 72 Chevy 1/2 Ton Big Block Suburban Highlander, 72 Chevy 1/2 Ton 4x4 Suburban, 72 Chevy 1/2 Ton Cheyenne Super, 72 C50 Custom, 69 Chevy CST C30 tow truck, 71 Chevy Big Block C30
68chevycst is offline   Reply With Quote
Old 09-19-2011, 08:35 AM   #4
67Mach1
67Mach1's Avatar
NOt the only reason but one of the big reasons I purchased this parts burb...
is for sale
Old 09-19-2011, 08:38 AM   #5
67Mach1
67Mach1's Avatar
I got the shoulder belts loose as you said yesterday. Not having any luck either feeding the webbing back into the lower covers nor am i at pulling on them trying to get them out from under the bolt head. Wonder if I'm planing on rewebbing them if I should just cut them?
I'd rather not...
Just to be sure, on the floor the rubber cover should come out from under the bolt or do I need to thread the webbing back into the cover as with the shoulder harness belts?
Thanks,
Thomas
is for sale
Old 09-19-2011, 02:55 PM   #6
leddzepp
Moderator
leddzepp's Avatar
the floor covers should just slide back off. they are not held by the bolts like the shoulder boots are.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-19-2011, 03:07 PM   #7
leddzepp
Moderator
leddzepp's Avatar
you may need to push forward on them a bit to "pop" the lip off the back, then they should slide back easily
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-19-2011, 04:06 PM   #8
67Mach1
67Mach1's Avatar
Thats what i had thought also. I was afraid to tear the boot so I didnt put a lot of effort into it. I'll go back and see what I can do. Will be later this week though.
THanks,
I;ll update when I can.
Thomas
is for sale
