Old 09-01-2011, 09:33 PM   #1
funkytechmonkey
funkytechmonkey's Avatar
Where to mount 5 gallon air tank with rear gas tank??
I am on a quest to find someone here that has found where to mount a 5 gallon tank on the 67-72 C10 that has a rear mount gas tank and a mild c-notch. There has to be someone here that has figured this one out..... and I'd rather not do an in-bed mount.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 09-02-2011, 05:02 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Where to mount 5 gallon air tank with rear gas tank??
Will it fit behind the seat inside the cab?
Keith
Convert to disc brakes.
Old 09-02-2011, 11:37 AM   #3
jimmydean
jimmydean's Avatar
On the side of the frame under the bed side. You have a space that should be plenty big enough for a 5 gallon tank depending on the dimensions. Either in front of the wheel or behind. My long bed has a space that is 30x14x12 that has a reserve gas tank in it now.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 09-02-2011, 11:48 AM   #4
funkytechmonkey
From the measurements I took.. it looks like it would hang down below the body if I did that. Id like to see if there is anyone here that has actually done it. I found one build that a guy did 2 - 3 gallon tanks... just no one with a 5 gallon.
Old 09-02-2011, 12:33 PM   #5
jimmydean
jimmydean's Avatar
What are the measurements of your tank? I know some of the 3 gallons are the some diameter as the 5 gallon, just longer. I know you could do 2 3 gallon tanks, one on either side of the frame behind the wheel.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 09-02-2011, 12:41 PM   #6
Shane
Shane's Avatar
your question is the very reason I went with 2- 3gallon tanks ... I could never come up with a good place to put a single 5 gallon under a stepside bed with a rear-mounted tank.
Shane is offline   Reply With Quote
Old 09-03-2011, 02:30 AM   #7
funkytechmonkey
Well most everyone I have talked to..... Even Nate at Porterbuilt says they all run 2 - 3 gallon tanks. So I upgraded my order with the Accuair system to the 2 - 3 gallon tanks and 2 compressors. Cant want to get them!!
Old 09-05-2011, 06:48 AM   #8
dznucks
dznucks's Avatar
I placed my two 3 gallon tanks in front of either tire. My thoughts were that the tire would kick stuff up at it if they were placed behind the tire. The bright side of going to two tanks is that you get an extra gallon or air.
I also used aluminum hard lines on my air supply side of the valve block to help ensure i never lost air. Eventually i would like to run hard lines to the bags.
dznucks is offline   Reply With Quote
Old 09-05-2011, 08:57 PM   #9
ENHANCED AIR RIDE
Short beds fit 3 gal, long beds fit 5 gallon 7" diameter tanks. Thats our experience.
ENHANCED AIR RIDE is offline   Reply With Quote
Old 09-17-2011, 08:51 PM   #10
Envy
Envy's Avatar
why not under the cab on the side of the frame between the front and rear cab mount?
Envy is offline   Reply With Quote
Old 09-19-2011, 05:19 PM   #11
kieth
kieth's Avatar
I am installing a 9" diameter under the bed in front of the rear axle on a 66 gmc swb fleetside.....tucked it up tight and it is above the frame rail so it should not show when the truck is back on the ground. Kieth
batteries out on camera will post pictures tomorrow....
kieth is offline   Reply With Quote
Old 09-19-2011, 08:12 PM   #12
Envy
Envy's Avatar
I mounted two 5 gal tanks (one on each side) between the cab mounts on the outside of the frame. You have something like 37 inches between the cab mounts. The tanks I got from AVS are 28x7. With the tank mounted so that it clears the cab reinforcement under the floor pans, the lowest point on the tanks is even with the bottom of the frame.
Old 09-19-2011, 10:37 PM   #13
funkytechmonkey
id like to see that.... I am running trailing arms and dual exhaust. So I dont know if it will work for me
