Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 09-20-2011, 07:21 AM   #11
trailrunner
Re: Power Brake Booster Adapter Bracket
Originally Posted by Captainfab View Post
All of my booster brackets are designed to fit each particular series of trucks. I do not have anything specifically for the '47-'59's. It is possible that one of the 3 that I do make would work for your application, but that would depend on what you are going to use for a pedal assembly, and which booster. Let me know.
Sorry, I forgot to include the pedal assembly info. My truck currently has a pedal assembly that "swings" from under the dash, vice the original one that came up thru the floorboards. The master cylinder that I removed was mounted to the firewall, similiar to the setup in my '69 Camaro. I'm content with what I have, except that I would like to add the power booster.
I plan to just buy an 8" or 10" booster from Autozone, unless I find that there is a reason this won't work. My truck has front disc brakes/rear drum brakes.
Thanks.
trailrunner is offline   Reply With Quote
