Old 09-19-2011, 10:25 PM   #1
Larry64
Cab mount bushings
Is it possible to change the cab mount bushings without taking the cab all the way off?
Thanks Larry
Larry64 is offline   Reply With Quote
Old 09-19-2011, 11:32 PM   #2
198plus
198plus's Avatar
Re: Cab mount bushings
Yes..
198plus is offline   Reply With Quote
Old 09-20-2011, 09:22 AM   #3
Clyde65
Clyde65's Avatar
from what I was told by some one who has done it many times, it is best/easier to do them by the side. left side then right side. I havent done it but this is what I was told. use a floor jack and a block of wood to prop the body up.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-20-2011, 10:24 AM   #4
Larry64
Thanks. Will do that.
Larry
Old 09-20-2011, 02:04 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
X2...this is what I did almost on a daily basis while mocking up chassis.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-20-2011, 02:28 PM   #6
oldtrux
oldtrux's Avatar
what mounts do you guys like rubber or poly?.....dan
oldtrux is offline   Reply With Quote
Old 09-20-2011, 02:31 PM   #7
Clyde65
Clyde65's Avatar
I have heard that poly squeak unless you grease often, I like the rubber myself.
Clyde65
Rebuild of Clyde
support our troops!
Old 09-20-2011, 02:33 PM   #8
oldtrux
oldtrux's Avatar
thanks clyde,i'll go with rubber!do you think that goes for motor/tranny mounts as well?
Old 09-20-2011, 02:56 PM   #9
Clyde65
Clyde65's Avatar
Well Oldtrux, I went with rubber all around. Front and rear suspension, cab mounts and everything. Some will say poly is great but I am not a fan. I have "0" squeaks period. That is why I did all the bushings, I hate squeaks.
Clyde65
Rebuild of Clyde
support our troops!
Old 09-20-2011, 03:12 PM   #10
oldtrux
oldtrux's Avatar
i hate squeeks too!!i'll follow your lead with rubber as well!thanks clyde
