Old 09-20-2011, 01:38 AM   #1701
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
I shot the last coat of primer at 5 this afternoon, then wet-sanded with 600 grit, prepped and ready to shoot. Don't forget to run a TACK CLOTH over everything right before you shoot.
Another trick if you see a speck of dirt or fuzzy while you are spraying is to half pull the trigger and only shoot air out to try and blow the speck off the panel. This only works of course if you haven't already stuck him with paint.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 09-20-2011, 01:43 AM   #1702
drewskiren
drewskiren's Avatar
Originally Posted by 68greg View Post
Drew, wow don't get on here for a couple of weeks and you redo a jeep and paint the cab of your truck and almost get the bed ready. And that cab......boy oh boy, looks like glass. Great job can't wait to see it when it's wet sanded and buffed. So when does the Drew's paint and body school open.
We'll start school with the 3 Ps. Prep-work, Patience, and Practice.
Drew
Old 09-20-2011, 01:45 AM   #1703
drewskiren
drewskiren's Avatar
Oh heck, who am I kidding. I finished this too tonight.
Drew
Old 09-20-2011, 02:10 AM   #1704
VA72C10
VA72C10
VA72C10's Avatar
Looks great! Getting really excited to see this beast together!!!
Old 09-20-2011, 03:45 AM   #1705
70LonghornCST
Moderator
70LonghornCST's Avatar
Originally Posted by 67cheby View Post
actually i think you need to write your own article
He practically did. Nice Job...which is an understatement. You have to be as proud as (or close to) the day you had your first child.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 09-20-2011, 09:25 AM   #1706
67cheby
67cheby
67cheby's Avatar
man ....you are the KING of GARAGE PAINT !!
67cheby is offline   Reply With Quote
Old 09-20-2011, 09:31 AM   #1707
drewskiren
drewskiren's Avatar
Houston, we have a problem.
Giant run on one rear side and orange peel all down the other upper side. Looks like a redo tonight. I'll tape off everything else that looks good and be able to really concentrate on just the upper sides. I was feeling the pressure last night of so much stuff to paint at once.
Drew
Old 09-20-2011, 09:44 AM   #1708
67cheby
67cheby
67cheby's Avatar
cant you just wet sand that out ??
Old 09-20-2011, 10:38 AM   #1709
FL71C10
Wax on, wax off! Just like the Karate Kid! Come down to Drew's Paint and Body school and he'll put you to work.
My shop teacher in high school used to do that. He would build hydraulic log splitters and the metal shop students would do the welding of the frames, the small engine shop students wouild rebuild the motors, and he would make the money! Smart guy!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 09-20-2011, 10:44 AM   #1710
drewskiren
drewskiren's Avatar
Yep, and I could then buff it down and pray I don't burn through the paint anywhere - or - since it is all taped up and so easy to spray....
The problem with counting on buffing is if you do burn through, you have to go back and completely retape/cover everything, blah, blah, blah = Nightmare.
Drew
Old 09-20-2011, 10:59 AM   #1711
67cheby
67cheby
67cheby's Avatar
makes sense !
Old 09-20-2011, 11:19 AM   #1712
mcbassin
Still Learning
mcbassin's Avatar
It's a real fine line between perfect wet coat and running on the floor. Sorry to see this happen to ya. Hope you have better luck on the second try.
Old 09-20-2011, 11:24 AM   #1713
drewskiren
drewskiren's Avatar
Ever tried to walk the edge of a razor blade????? Its about like that.
Drew
Old 09-20-2011, 11:25 AM   #1714
lyrikz
PITbut
lyrikz's Avatar
Drew, very easy to wetsand that out. Just use a solid bloc, and you will be fine. You should of seen the runs in my truck. HOrrific compared to yours. Mine was black and came out perfect.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 09-20-2011, 01:27 PM   #1715
wicky
wicky's Avatar
I dnt know if this is ur first paint job or not but don't be scared of wet sanding and buffing. Especially a run cuz you've got to keep in mind that there's already to much paint there anyway. If you put three coats of clear on it you can do alot of sanding and buff before you burn through. Just my. 02 though.
wicky is offline   Reply With Quote
Old 09-20-2011, 02:37 PM   #1716
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
^ Single stage, not base coat clear coat.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 09-20-2011, 04:03 PM   #1717
oldman3
oldman3's Avatar
Drew, have you ever used a painter nib file, their about 1-1/2" square and look like a file. Go over the run and it cut them down little by little, most paint supplies have them. I've also used a single edge razor blade, hold with both hands and drag over the run, it will also cut it down. Then wet sand and buff....Jim
oldman3 is offline   Reply With Quote
Old 09-20-2011, 04:32 PM   #1718
drewskiren
drewskiren's Avatar
I have a nib file and a plastic device that holds a razor blade for you like you were saying. Can't find them right now though.
Drew
Old 09-21-2011, 02:16 AM   #1719
71Sleeper
71Sleeper's Avatar
I think Drew has got this guys....The proof is in the pudding, as one might say. Drew you are making great progress and I could only hope to be as detailed on my build as you are with Young Frankenstein. Can't wait to see this beast together. I log on everyday just to see the progress. Keep up the hard work.
71Sleeper is offline   Reply With Quote
Old 09-21-2011, 07:43 AM   #1720
jeffg1010
jeffg1010's Avatar
Originally Posted by 71Sleeper View Post
I think Drew has got this guys .... The proof is in the pudding, as one might say.
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 09-21-2011, 09:36 AM   #1721
Pop's C-10
Pop's C-10's Avatar
Smile Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
pudding..where
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 09-21-2011, 01:02 PM   #1722
ERASER5
ERASER5's Avatar
Originally Posted by Pop's C-10 View Post
pudding..where
Yea, but what flavor is BLUE?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-21-2011, 04:05 PM   #1723
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Hey, at least it was only on the upper areas! I hate it when you are spraying a long and then come back and see it ran! I tend to spray heavy and have to learn to walk away. You'll get it Drew!
Ryan
1969 Chevy milk truck
Old 09-21-2011, 07:51 PM   #1724
quandelgarage
quandelgarage's Avatar
looks sweet keep it up
old school like your mother.....
My Build--- Body dropped 67 service truck http://67-72chevytrucks.com/vboard/s...d.php?t=485504
quandelgarage is offline   Reply With Quote
Old 09-21-2011, 07:59 PM   #1725
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Drew keep up the good work its almost there...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
