Old 08-14-2003, 08:59 PM   #1
nejeff
Having trouble "dialing it in" HELP!
Hi,
I'm a novice at these things but I pride myself at figuring these things out. Can't do it this time. Here's the story:
Put 307 in my 72 and did the following:
Changed plugs .035, New wires + cap, condenser, rotor + points new, rebuilt 2-barrel out of the box.
I set the dwell at 30 and the timing at 8 btdc but it is still acting like it's getting too much gas and feels like it's just a screw turn or something away from running good. It feels like it's being held back some. Some hesitation and a little backfiring.
I have adjusted only the idle screw on carb.
What's the proper way to get this baby tuned? What am I missing here?
Thanks guys
72' Chevy Super Cheyenne LWB
72' Chevy C-10 (307 Parts Truck)
nejeff is offline   Reply With Quote
Old 08-14-2003, 09:12 PM   #2
ddsmith
Glowing since 1978
ddsmith's Avatar
If you feel the distributor is adjusted correctly and you said the carb is a rebuilt 2 Barrel. I would suggest adjusting the idle mixture screws on the carb. Try using the info at this link for the adjustment. http://www.gmcpauls.com/Tech%20Tips1.htm go to the page where it talks about vacuum gage use then read down to the part about idle mixture adjustment.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 08-14-2003, 11:24 PM   #3
Locutus
Locutus's Avatar
I notice he says 17-22 is normal. I assume this applies to stock motors? What about a 284 duration cam what would be normal?
Mike
Locutus is offline   Reply With Quote
Old 08-14-2003, 11:55 PM   #4
ddsmith
Glowing since 1978
ddsmith's Avatar
If you look at the information it says that a reading that is steady from 10-16" may be caused by a big cam. Low vacuum reading are an expected outcome of a big cam and I think it is the overlap that causes the low vacuum at low rpms.
Old 08-15-2003, 12:24 AM   #5
cdowns
cdowns's Avatar
i'd go with a little more dwell 32-34 and open the plugs to 38-40
