#26 |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Hooking up two batteries together on my 73 c10?????
I forgot to mention that I'm running double 00 gauge cable not the standard 4gauge.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#27 |
wow, that was a lot of responses. It isnt that hard. You have more then enough information.
My turn to add to this data dump. Can you say OPTIMA.
79 C10 Stepside, on 22's, 350, AFR 2.02 Heads, Victor Jr, Holley 770 Ultra, 12 bolt 3:73, 700r4... |
#28 |
Bingo on the optima. This situation does not required higher cold cracking amp but needs a separate battery to run a compressor without harming the main running battery. Optima or any gel cell deep cycle battery will work better because they can be discharged and recharged without damage to the battery. I've seen optima yellow tops last ten years or more and get discharged on a regular basis.
Posted via Mobile Device |
| Bookmarks |
