speedometer cable question
![]() which die do I use to clean up these threads. Can't get my speedometer cable started because the threads are messed up. Posted via Mobile Device Posted via Mobile Device |
Re: speedometer cable question
If you have to remove it to clean it up just replace it with a new one then your guaranteed it wont leak should be less than $28.00
Fuzzy |
The Older Generation
I'm pretty sure that is going to be an odd thread but don't know that for a fact. Take the bolt out and it will slide right out then you can clean the threads up with a three cornered file. Make sure the speedo gear comes out with it. If that doesn't work someone on the parts board should have one for a four speed. LockDoc
#4 | |
#5 | |
That is a different story...I don't have a clue. In that case I would have the Mods move it to the 4x4 forum... LockDoc
there is a hold down bolt that you remove and that speedo bullet will slide out with the gear
Fuzzy |
