Old 09-22-2011, 05:19 PM   #3
Yupiamlo
Yupiamlo's Avatar
Re: 1986 C10 High Beam/Wiper
bump, if your looking from the side of the column that the tilt handle is on, with the side cover off,
their is an arrow shaped cut away, where you can see the high beam rod,
I just made the rod sit on the inside of that cut away, and now it is stuck there,
and theirs a small circle spring that would be in the way of the rod anyway...
are we sure not under the cover,but outside the metal arrow cutaway, and if it is... how don't I make the wipers go nuts
Yupiamlo is offline   Reply With Quote
