Is there any diffrance between 1/2 and 3/4 ton trailing arms?
I usually hang out on the 47-59 side of this board. what I am tryng to find out is if lat 60s 1/2 and 3/4 ton rear trailing arm interchange. they look like they are the same aside from a plate under the spring.
thanks Mark |
Re: Is there any diffrance between 1/2 and 3/4 ton trailing arms?
Just the plates they interchange
Fuzzy |
Thanks, that's what I thought. that makes life easier I have a 1/2t with a body if you can call it that. and a 3/4t with no body and I need the X member as well as the trailing arms.
Mark |
