09-23-2011, 01:26 PM | #1 |
Re: Quick C60 question.
I agree with the Captain....as far as the I-6's go..
But somewhere in my memory banks.....back in the late '70's , I did a V-8 swap in a C-6o, and that one had the two bell housing mounts and one in the front center under the harmonic balancer.... Or maybe I was smokin the "Tall Grass" and just thought that's what I saw...
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
09-23-2011, 11:50 PM | #2 | ||
60-66 Nut
I'm not sure on that. But if it has a small block in it currently, your '70's engine will bolt right in. However if that V8 happens to be a 348/409, then you would have to come up with a small block front saddle, if that is the style it has.
In the early '70's GM went to the front saddle type motor mount in the medium duty trucks. Quote:
