Closed Thread
Old 09-22-2011, 01:26 PM   #1
RUSHNBOBO
how bout some pics of custom cold air setups
here's mine to start it off, the ends of the hoses are out of view....they run to a 4" mount bolted to lower corners of the rad support and draws air only from outside the engine compartment.
RUSHNBOBO is offline
Old 09-22-2011, 01:31 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: how bout some pics of custom cold air setups
I did mine several years ago.
Over view:
Inlet hole for the air.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 09-22-2011, 05:40 PM   #3
68 short step
68 short step is offline
Old 09-22-2011, 06:18 PM   #4
Andy4639
Old member
Andy4639's Avatar
Cool Re: how bout some pics of custom cold air setups
68 short step,
hope you never have to pull that radiator! Nice metal work by the way. I like the clean look.
Andy4639 is offline
Old 09-22-2011, 06:37 PM   #5
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Originally Posted by Andy4639 View Post
68 short step,
x2
That's just sick!
Everyone: good job!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline
Old 09-22-2011, 07:07 PM   #6
AirSpeed
AirSpeed's Avatar
Nice work guys! Does the cold air intake make a noticeable difference, can you actually feel the difference! They all look very nice!
AirSpeed is offline
Old 09-23-2011, 05:37 AM   #7
RUSHNBOBO
Originally Posted by 68 short step View Post
Looks good ...did you have to use bubble connectors of some sort on the ends, to prevent engine movement from cracking the tubing?
I am thinking doing a full fabricated polished aluminum setup and eliminate the flex tube. Spectre will weld and re-polish the tubing, after you cut, fit and mark all the pieces.
You get approx 1% increase in HP for every 10 degrees you lower the intake air temp.
So just for an example, figure a under-hood temp of 180 degrees, and the ambient temp outside the engine compartment of 90 degrees. You would have a 90 degree reduction in intake temp.
This example would give you approx 9% increase in HP, note there are many complicated variables which can vary this number involving calculating the exact air density. But it gives a good idea of the free horsepower to be had from a engine drawing air from outside the engine compartment vs. one which draws from directly behind the radiator
Can you feel the gain?.......
in ideal conditions it could be as much as 25-30 HP...... and vs. a non cold air system ....and that's definitely enough to "feel".
Old 09-23-2011, 10:36 AM   #8
Andy4639
Old member
Andy4639's Avatar
What I have never understood is a cold air setup that the tube ends right in front of the motor and it's sucking the same hot air it did before. I just don't understand it.
I talked with a guy at a show who had a beatiful 68 camaro and his cold air ran down under the motor and stoped. No scoop nothing just a tube. I asked why he did it this way and he said it was the only way it would pull air in. Cold air isn't pulled in it's suppose to be forced in when you go down the road. That's why you want it to have an opening on the front end of the vehicle to have the free flowing air to be forced into it. I have the sheet metal covers between the grille and the rad support to help with this also.
On a nice cool day you can feel a differance in the way the motor reacts.
Andy4639 is offline
Old 09-23-2011, 11:32 AM   #9
Dunenutt
Newbee
Dunenutt's Avatar
Dont have a pic of it with the hose on. I guess it's a cowl induction/cold air setup. I don't know how well it works yet.
Dunenutt is offline
Old 09-23-2011, 11:50 AM   #10
Andy4639
Old member
Andy4639's Avatar
You going to have a NASCAR type setup. Keep us posted on it looks like a cool idea.
Did you block off the vents inside to force the air back out the tube?
Andy4639 is offline
Old 09-23-2011, 12:25 PM   #11
RUSHNBOBO
[B][COLOR="Red"]What I have never understood is a cold air setup that the tube ends right in front of the motor and it's sucking the same hot air it did before. I just don't understand it.
Iv'e seen a bunch done this way....and it's definitively not the optimum setup. Ideally the air should come from "outside" the engine compartment. Some will run them down in the corners near the bottom of the rad support, where they terminate and draw air from there, is this better than an open element setup? ...Sure any time your not pulling air from directly behind radiator it's cooler, but how much?
Iv'e open my hood after running up to full temp and put my hand both inside the rad support and outside in the same place, down near the bottom. The temperature difference is substantial, probably 40-50 degrees, this is horsepower lost maybe 4-5 percent, vs. isolating the intake completely outside the engine compartment.
Old 09-23-2011, 12:28 PM   #12
jaros44sr
jaros44sr's Avatar
do you have pic, or link to these bubble connectors you refer to....I planned on making mine like yours, but I would like to pull the air from the cowl area
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline
Old 09-23-2011, 12:59 PM   #13
RUSHNBOBO
it's more commonly called a "hump hose"coupler...it give's the system the flex you need when using solid tubing
Old 09-23-2011, 03:34 PM   #14
Andy4639
Old member
Andy4639's Avatar
Wink Re: how bout some pics of custom cold air setups
Iv'e seen a bunch done this way....and it's definitively not the optimum setup. Ideally your right, the air should come from "outside" the engine compartment. Some will run them down in the corners near the bottom of the rad support, is this better than an open element setup? ...Sure any time your not pulling air from directly behind radiator it's cooler, but how much?
Yes it's not the best but most of them are that way. That's why I did mine the way I did it. I know the plastic hose isn't the greatest insulator but with it being semi forced through I figured the air isn't loosing that much temperature differance.
Andy4639 is offline
Old 09-23-2011, 03:44 PM   #15
Dunenutt
Newbee
Dunenutt's Avatar
I have the vintage air kit inside, and the blower housing blocks that vent. I left the vent flap in, but sealed it shut. Judging from the past, there should be more than enough flow, even with the driver side vent open.
Dunenutt is offline
Old 09-23-2011, 03:50 PM   #16
Andy4639
Old member
Andy4639's Avatar
Cool!
I like it.
Andy4639 is offline
Old 09-23-2011, 04:02 PM   #17
67chevemall
67chevemall's Avatar
Very creative! kudos!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline
Old 09-23-2011, 04:24 PM   #18
RUSHNBOBO
Here's a great read about "Ram air intake myths" ......not to be confused with "cold air intakes"
The Ram Air Myth by Dave Rodabaugh
http://www.paladinmicro.com/documents/RamAirMyth.pdf
Old 09-23-2011, 04:38 PM   #19
RUSHNBOBO
it should work fine, as the cowl area is and isolated from the engine compartment, the temp drop there would be the same as anywhere else.
Old 09-23-2011, 08:31 PM   #20
Dunenutt
Newbee
Dunenutt's Avatar
That made my brain hurt! But very informative.
Dunenutt is offline
Closed Thread
