#26 | |
Re: Can you mount 4-link bar in leaf spring bracket?
#27 |
Building Dreams out of Dimes!
BINGO!
http://www.airbagit.com/product-p/link-tri-gm-03.htm ![]() List Price: $838.80 Our Price: $699.00 You save $139.80! Year: 1973-1987 Make: CHEVROLET Model: C10 10-BOLT ![]()
1981 Chevy short/wide. SB400 350th |
#28 |
HOLY CRAP! THESE GUYS HAVE HORRIBLE REVIEWS!!!!
WELL THAT'S GREAT! ONLY TRIANGULATED 'BOLIT ON' KIT I HAVE FOUND! ![]() Oh well from what I have read it will not be 'bolt on' it will be low quality, and I'll have problems with customer service. That is just what I have read from 15 minutes of reviews. The only postive reviews I have founds is on their own website..... ![]()
#29 |
If you buy from them, you're definitely taking a risk.
I do not like the upper link arrangement in the pic either. I don't get running the 2 bushings so close to each other when a single bushing that allows for better articulation would be much better (a true 3-link). The close proximity of the differential side of the bars combined w/the centered front mounts isn't going to do a good job of keeping the rear end in place w/o binding. Binding breaks parts. Typically, when the differential end of the links are located so close to the C/L of the rear-end, the front end of the links are attached to each frame rail vs. merging toward the center of the vehicle.
