Happy to be here
![]() Join Date: Mar 2000
Re: 1st of many probably dumb questions with 63 c10 brake conversion
It may be a bit more work than you expected, but the results will be worth the effort. You do not have to pull the motor, you can support it instead. You don't have to pull the crossmember either. You can install the newer A-arms to your old crossmember.
#2 | |
There is also a 3rd option. Keep what you got, and just replace the balljoints, spindles, and steering components you were gonna need to replace anyways. It'd be wise to still get conversion hoses, but 73 to 87 hoses will fit. You need to drill a hole in your crossmember for the mounting tab (see my build thread I talk about it in there on PG 4 I think). This is necessary to take up the slack and keep it from rubbing Posted via Mobile Device
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
