Life is Good !
I was looking to put an electric water pump on my 350. I like the CSI water pump, it says it pumps 30-37 GPM. Has anyone here used one before? I was looking for some input, pros and cons and such. If anyone can help that would be great. Thanks Landon
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
Landon,
It's been questioned before whether they actually pump enough water...I have one on my 66 (pic attached) and have cooling problems. However it's a race motor that wasn't designed for steet duty....but after asking several people and doing some research the continual response was that these pumps are for 1/4 mile cars. Thats not to say it won't work...assuming you have a stock motor and a good/large radiator.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
Mike
Why do you want one?On the street you will not lose that much HP.If it is a street truck,I would go with a good belt drive pump.If you want to free up some power,put in a good set of electric fans with a shroud.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Life is Good !
I was planing on going with the electric fans also. I was going for looks and to save as much hp as possable.
Livin' it up.
![]() Join Date: Nov 2001
i've been told you 'can' run them on a street motor as long as things are pretty mild as they dont have nearly the flow of the mechanical models. and for the price tag get yourself a good aluminum one from weiland or someone for half the cost... that way you'll not have overheating issues.
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
Miket
That thing looks fast! How fast is it and do you have it on dragtruk.com if not you should have. That site was started by a bunch of dodge guys. I can't wait to get my drag truck done but my chassis man is way slow!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
MikeT, what kind of fan setup is that?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
DJRACER:
it's not my truck....rather my Chevelle...don't know how fast...was told 9.40-9.80 by the builder on initial 6 passes....but things like this are always exagerated. 72gmcshorty: The fans on my Chevelle are from Flexalite (http://www.flex-a-lite.com/) twin 14"'s that run all the time...no thermostat. I have twin 14"'s in my truck that are very nice...I can post pics if you want.
its all about the +6 inches
The aftermarket industry says that electric water pumps can not really be used on the street. They say when detroit (Or japan probably) switches over to a 32 volt system, (!!!) then electric water pumps will be able to do the job properly.
