Old 09-27-2011, 03:39 PM   #1
robnolimit
robnolimit's Avatar
Re: 63-72 Chevy P/U Rear Shock Mount System
I think you are refering to the lowering block. It is 2" thick, although they are avail. in 1/2", 1", 1 1/2" also. I like to use a block for the firt 2" of lowering, this aproach keeps the spring as long as possible for a better ride.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 09-28-2011, 02:56 PM   #2
kieth
kieth's Avatar
what about the brackets on the crossmember for the trailing arms, should we still raise them up ?
kieth is offline   Reply With Quote
Old 09-29-2011, 02:32 AM   #3
robnolimit
robnolimit's Avatar
Yes, I would still move them up, and/or flip them.
Old 09-29-2011, 05:07 PM   #4
kieth
kieth's Avatar
Thanks Rob, I am in the process of doing this as we speak, will use the 2x2 block, am getting ready to order your shock relocator kit, and at the same time we are moving the rear axle back 1.5" and adding a cpp notch kit. Busy Busy
I would order your fatboy panhard rod but cannot afford it right now. may add it later. We are also slamming a 65 LWB Fleetside so too many irons in the fire.
Thanks again , Kieth
Old 09-29-2011, 05:14 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Re: 63-72 Chevy P/U Rear Shock Mount System
Got the shocks redone. Here are the pictures of the passenger side.
I took this one looking through the wheel.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
