Old 09-24-2011, 02:23 PM   #1
AirSpeed
AirSpeed's Avatar
Is it okay to mount a step to back of rocker?
My truck has a four inch lift and it's just a little to high to get in easily, I've looked at a lot of steps and I see a lot that bolt to the back side of the rocker, I am worried if a heavy person stepped on it mounted that way that it could twist the rocker. Is the rocker panel really strong enough to bolt a step to? What would be the best step and mounting options?
AirSpeed is offline   Reply With Quote
Old 09-24-2011, 04:57 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: Is it okay to mount a step to back of rocker?
If you mount it to the rocker, I would get a heavy piece of flat iron and run to the frame also. Just to be safe
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-24-2011, 05:06 PM   #3
AirSpeed
AirSpeed's Avatar
I think I'm going to do something like that. I just ordered a pair of Carr "Hoop II" polished steps, they have a few mounting options. I just can't see the rocker not twisting down after a while of people stepping on them.
Old 09-27-2011, 05:05 PM   #4
AirSpeed
AirSpeed's Avatar
I got my new steps today, CARR super hoop II, the instructions say to center the step with the front edge of the seat, have any of you used one of these steps and did you mount it centered with the front edge of the seat or did you find a better position? Thanks!
