Old 09-28-2011, 12:38 AM   #1
dliving69
dliving69's Avatar
15x8 rally's
Looking into some 15x8 rally rims, what would the best tire size to go with them rims? Any suggestions??
dliving69 is offline   Reply With Quote
Old 09-28-2011, 09:12 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 15x8 rally's
are you stock height or lowered?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-28-2011, 09:14 AM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 15x8 rally's
Also, 2wd or 4x4?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-28-2011, 09:34 AM   #4
jhwkns
Registered Cruiser
jhwkns's Avatar
Re: 15x8 rally's
for your truck 255/70/15
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 09-28-2011, 10:12 AM   #5
dliving69
dliving69's Avatar
Re: 15x8 rally's
My truck is at stock heigth right now should be lowering in the future, and its 2wd...I am wanting street tires..no a/t or anything..more rubber on the road.
Old 09-28-2011, 10:21 AM   #6
big_al_71
big_al_71's Avatar
Re: 15x8 rally's
275-60-15
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-28-2011, 11:44 AM   #7
dliving69
dliving69's Avatar
Re: 15x8 rally's
Should i stagger with some smaller in the front..or stick with that all around?
Old 09-28-2011, 12:10 PM   #8
jocko
jocko's Avatar
Re: 15x8 rally's
for stock ride height (now) or if you know you want same size wheel/tire all the way around, recommend 255-70-15 all the way around - these are tall tires and fill wheelwells nicely.
if you know you're gonna lower it, then I'd stagger and go with 275-60-15 (rear) (i.e. wider, but still tall enough) and 235-70-15 (front) i.e. narrower and slightly shorter (clearance if you need it when lowered) although I'm pretty sure someone could confirm on here whether a 255-70-15 would have interference problems on a lowered truck.
Avoid narrow 60's (too short) and 50's period. (i.e. 275-60-15 is a tall tire, so good to go - but DON'T run something like a 235-60...)
Old 09-28-2011, 12:16 PM   #9
Clyde65
Clyde65's Avatar
Re: 15x8 rally's
I agree with Jock-o. although mine is a 65, I have BFG Radial T/A 275/60/15 on Ralleys in the rear and 255/60/15 on front, but I will change front to 235/70/15 so the tires are the same height and fill everything out nicely.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-28-2011, 12:55 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Re: 15x8 rally's
275 60 15's on 15 x 8 rallies in the back.
215 70 15's on 15 x 7 rallies in the front.
This combo gives a nice rubber rake to a lowered truck, imo. I am running this set up with a 5/7 static drop.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-28-2011, 01:02 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 15x8 rally's
I ran 235-70's on my 15x8's, up front. I ran 275-60's on the 15x10's out back.
I currently am running a 16x7 on my GMC and running 255-70's on all four, so I can rotate them.
Having different sized tires on the same size wheels, prevents tire rotations. When I replace the tires on my 16's, I'm going with a shorter, i.e., 60-series, tire up front. Yeah, I know....tire rotations going by the wayside. However, the visual aesthetics are an issue with me.
Member Nr. 2770
Old 09-28-2011, 01:35 PM   #12
big_al_71
big_al_71's Avatar
Re: 15x8 rally's
This is the set up I have ready to go on my truck right now
245/60/15's up front and 275/60/15's in the rear 15x6 up front and 15x8 in the rear..
I will post picts once I am done with it. This is just to change the look from weekend to weekend.
Old 09-28-2011, 03:13 PM   #13
dliving69
dliving69's Avatar
Re: 15x8 rally's
so they are taller, but are they decentley wide..right now i have tall ones and they seem to just sit in to much under the fender i want some that will fill them out a lil more outward
