Old 09-27-2011, 11:44 PM   #1
dtkarst
Probably a dumb question...but.
This may be a dumb question but my 66 has a 327 in it from the factory with manual steering. So my question is that in order to make it power steering, could i just look for a power steering pump, brackets, lines, etc from a car or does it have to be from a truck? And could it even be from a 350? Again, probably a dumb question but whatever help I can get would be helpful.
dtkarst is offline   Reply With Quote
Old 09-28-2011, 01:06 AM   #2
A.T. RockDriller
A.T. RockDriller's Avatar
Re: Probably a dumb question...but.
Yes, yes, yes, no, yes....and not really.
Vintage is more important than application on that one.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 09-28-2011, 10:00 PM   #3
dtkarst
Well I can get brackets pump and all the equipment needed for a car. That is why i am asking if they will bolt up to a truck or not.
Old 09-28-2011, 10:42 PM   #4
awbrown
They should , get the whole 9 yards and make sure that if it needs the head bolt holes to mount up that you do in fact have them.... making PS work with existing alt etc could be tricky unless you can see that the donor vehicle has the same brackets...
awbrown is offline   Reply With Quote
Old 09-29-2011, 12:57 AM   #5
Captainfab
60-66 Nut
Assuming that your 327 is completely original, you will need the PS pump, brackets and pulleys from a '72 and earlier truck or a '68 and earlier car. Those years are compatable with a short water pump small block without heads with accessory holes. And yes parts from a 350 will work, as well as parts from a 283 or 307. If by chance someone has changed the water pump to a long one, then you will need to do a little fabricating unless the heads are '68 and newer.
Old 09-29-2011, 01:49 AM   #6
jocko
jocko's Avatar
Now THAT'S what I call good gouge.
Old 09-29-2011, 02:16 AM   #7
dtkarst
Yes it is completely original 327. and thank you for the information that is helpful.
