09-24-2011, 07:12 PM | #1 |
LS1 Swap Fuel Setup
Looking for some more info and ideas on the LS1 fuel tank and fuel line swaps.
Not sure if I want to go with an external pump and fuel cell? Does anyone have any suggestions? |
09-24-2011, 08:03 PM | #2 |
Re: LS1 Swap Fuel Setup
In my opinion, the in tank pump is the way to go. It is quieter, and out of the way. What engine/trans package are you going to use. We NEED pics.
Jeff |
09-24-2011, 08:11 PM | #3 |
I agree plus the fuel keeps the pump cool when submerged, Look at the builds above that Delmo is doing he has some good ideas on LS motors
09-26-2011, 10:11 AM | #4 |
what are you putting the LS motor in?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-26-2011, 12:50 PM | #5 |
meowMEOWmeowMEOW
i run a fuel cell and external pump. I like running an external pump for serviceability, and it made it easier to switch to a larger pump or dual pumps if/when my setup needs more fuel.
if you have an existing fuel cell (as i did when i bought my truck), its easier to convert to an external pump, since you don't have to modify the tank for the intank pump setup.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-29-2011, 10:19 AM | #6 | |
Home Built '87
- depends on your current set-up verses if you are going to rebuild it. I went with in-tank pumps b/c I wanted quiet operation and I wanted to keep them cool, but I had it all apart at the time and had the option of going either way....but I also wanted to keep dual tanks for long drives which I'm going to do lots of in this truck.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
10-01-2011, 10:41 PM | #7 |
im running a camaro tank with a truck pump. only caus the camaro pump was broke. the truck pump is clocked different so the fuel sender float hits the inside of the tank so my gauge only reads up to 3/4 but it still tells me when its empty so o well. it fits inside of the frame on a 68 though
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
06-08-2012, 09:49 PM | #8 |
What year camaro tank? I just bought an 02 tank... wondering what I'll have to do to mount it.
