Old 08-16-2003, 06:03 PM   #1
BigRed
Grant Steering Wheel Installation ??
I'm trying to install my new Grant wheel. I bought the 3196 Grant installation kit. I'm having a problem because the Grant hub is not sliding over my spline? At first, the backing plate on the hub was blocking the plastic horn shaft from coming through so I trimmed the backing plate. Once I got that done, it still won't fit over the column shaft. I thought maybe the plastic horn piece was still hitting, but I turned the hub around and it won't fit that way either.
Am I doing something wrong? Did anybody else that has Grant wheels have this problem?
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 08-16-2003, 06:22 PM   #2
gldevall
gldevall's Avatar
Mine went on pretty easy.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 08-16-2003, 06:31 PM   #3
kballan
kballan's Avatar
Mine went on with no problems at all. Are you sure they gave you the right installation kit?
Kent Ballan
ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP!
kballan is offline   Reply With Quote
Old 08-16-2003, 06:33 PM   #4
Prerunner1982
Prerunner1982's Avatar
might double check and make sure that is the right part for the box. went to pick up an oil filter the other day and picked up the PF35L for $9.99 opened it up to make sure and the part number on the filter was for a PF1218 for $2.99. the PF1218 fits but its for a van and wasnt the top of the line special filter. if i hadnt checked i would have paid way too much for a filter.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-16-2003, 06:39 PM   #5
BigRed
Thanks guys. I have double checked to make sure the part number is the correct one. I'll take it back and get another one. It very well may be the wrong part in the right box.
Scott Shelbourne
Old 08-16-2003, 06:49 PM   #6
kballan
kballan's Avatar
Kinda sounds that way. The hub should fit over the steering column with no problems.
Kent Ballan
Old 08-16-2003, 10:40 PM   #7
apstguy
LED King
apstguy's Avatar
Mine fit fine, but it made my steering wheel off and tilt to the left (which is more comfortable & why I haven't fixed it)
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 08-17-2003, 04:14 PM   #8
BigRed
Well, took back the install kit, got another one (same part number). And this one had the right parts in it! Amazing how well a part fits WHEN IT'S THE RIGHT ONE in the box!
Scott Shelbourne
Old 08-17-2003, 07:01 PM   #9
kballan
kballan's Avatar
LOL! Been there.
Kent Ballan
Old 08-18-2003, 12:43 AM   #10
Prerunner1982
glad things worked out for ya!
Jon
Oklahoma Roll Call
