Air bag kit for 2nd gen camaro subframe?
Im looking for an economical air bag kit for just the front of the '59 w/ a '79 camaro subframe. any thoughts?
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
Re: Air bag kit for 2nd gen camaro subframe?
Would something like this work?
http://www.auto-addicts.com/product_p/baga-25aaaa.htm I dont need a compressor. I have some 2,200 psi air bottles that I can easily refill. I was thinking that a hidden dial regulator like what you would use to adjust the output pressure for your air compressor would work. I dont want "switches" in the cab. What do you guys do? I would think that I could make something instead of buying these: http://www.auto-addicts.com/ProductD...F7081&CartID=1
#3 | |
Old Heap Driver
My 73 C-10 is bagged and the 50 I'm building will be bagged. I wouldn't run air ride without switches in the cab. I've had friends that started out with tanks and eventually went with on board compressors. If you develop a leak you'll need air asap.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
That makes sense. Do you have pics of the neccessary trimming by chance? Maybe I will start with the high pressure air bottles and move to a compressor later. Are those bags acceptable for using on a camaro? I want to be able to air it out to the bump stops and be able to inflate it to normal stock ride height. Im a total noob when it comes to air bags. Thanks for the help guys!
Old Heap Driver
Those bags look OK but I've not heard of the brand.
As far as cutting the spring tower.....I'll try and get some pictures this weekend of my S-10 chassis to give you a general idea. My setup will be using the same style bag cups, I'll get you some pics of those as well.
Ok, I am going to give making my own brackets a whirl. I ordered two each of the upper and lower universal brackets. I'll need to pick up some 5.5" tubing/pipe to weld onto the upper to space it down. I would REALLY appreciate some pictures to help guide me along! I want to be able to get it up to the factory-ish camaro height, as well as drop it down. Here are a couple of other bags I was looking at:
Slam Specialties RE Series 5" Air Bag Single Port 200psi Sale Price $85.00 5.5" Diameter. 2.9" Collapsed Height 8.0" Extended Height -or- Slam Specialties RE Series 6" Air Bag Single Port 200psi Sale Price $85.00 6" Diameter. 2.9" Collapsed Height 10.0" Extended Height I was leaning toward the 6" bag since its extended height is a couple of inches taller. I want to be able to get it up to the normal ride height of the camaro suspension. Thanks a bunch! Nik
Old Heap Driver
I don't think you want to space them down. I think you'll have a better visual once I post some pictures.
BTW.....You may want to post some bag questions in the suspension forum. You may get a quicker response.
Old Heap Driver
Here's a link to check out. these deal with S-10 frames but there isn't that much difference for what you're trying to accomplish.
http://www.blazinlow.com/index.php?what=tech/bags/bags
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. Last edited by S10Fan; 02-02-2011 at 09:28 PM. Reason: removed bad link |
Good info! thank you! I see what needs to be cut now. Looks like quite a bit of work! haha. I better get on it! I wanna start working on a GTO project one of these days!
Yellow truck club
over in the suspension forum there are a few guys offering deals right now
here is one http://67-72chevytrucks.com/vboard/s...d.php?t=440242 AVS Jason is a nother one
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 02-02-2011 at 10:22 PM. |
Thank you. I found that earlier after posting this. I actually have spoken with Jason today and will get all set up from him. Thanks!
I HAVE PICS OF MY BAGGED 57 IN MY BUILD THREAD IN THE " PROJECTS AND BUILDS SECTION, http://67-72chevytrucks.com/vboard/s...d.php?t=484701 HOPE THEY HELP., oops sorry for the caps.
Learn to deal with reality, or reality will deal with you. |
