Old 10-03-2011, 12:40 AM   #1
lenguini
lenguini's Avatar
Poor cab support fitment
Hi all,heres a few pics of my problem.The first 2 are the drivers side,the second 2 are the passenger side.Im not sure there is supposed to be that wide gap at the rocker/cab corner I was told this is normal and it is generally filled with seam sealer.The drivers side is all around poor fit.Maby its poor cab corner fitment ?
Let me know your thoughts please.
Thanks,
Ed
lenguini is offline   Reply With Quote
Old 10-03-2011, 10:01 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Poor cab support fitment
looks like your drivers side lower rocker is bent a little at the back, sealing up the gap...
you might want to do 2 different things, seal it up completely so no dirt/water can get in and rust it out, or make the gap a little bit bigger so that dirt will not have a chance to build up in there....
most originals that I get into that are not rusted, are packed full of dirt.
Old 10-03-2011, 08:10 PM   #3
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I went thru all of my pics to find you a good one. I didn't find a good one for comparison, but I found this one.
It looks like the drivers is but welded to the inner rocker. It's hard to tell, but I don't see a flange like on the pass side.
I wouldn't be too concerned about the gap along the bottom of the support where it meets the rocker. The gap like Jon said will definately keep stuff from building up.
Alan's Classic is offline   Reply With Quote
Old 10-03-2011, 08:21 PM   #4
Alan's Classic
I did seam seal as many joints as possible. No, it's not factory. The factory's plan for corrosion protection didn't work very well. I also used an inner rocker spray that is a waxy substance to help on the inside. I also use weld thru primer on all the welds.
