Old 10-04-2011, 05:52 PM   #1
jesse977
jesse977's Avatar
I removed my gas tank today (pics) have a few questions..
I removed my gas tank check it out. My buddy says that the caked on dirt isnt dirt but a kind of protectant gm sprays on the gas tanks. I think my buddy is a idiot and think its just caked on dirt. When I scrape the caked on dirt with a screwdriver it comes off easily. My truck is a 74 swb.
jesse977 is offline   Reply With Quote
Old 10-04-2011, 05:54 PM   #2
jesse977
jesse977's Avatar
Re: I removed my gas tank today (pics) have a few questions..
Heres the inside of the tank has some minor rust in the bottom. I sanded it with some fine sandpaper and it came off pretty well (after pic was taken). I still dont know if I should clean this one up or buy a new one. The bottom just has this light rust the rest of it is in very good shape.
Old 10-04-2011, 05:56 PM   #3
jesse977
jesse977's Avatar
Is this how the cover should be or is it cut? I have no clue.
Old 10-04-2011, 05:58 PM   #4
jesse977
jesse977's Avatar
My fuel gauge is stuck at 1/4 and doesnt move. Im going to but a new floater. Heres the old one. Notice the frayed wire, may that be the cause? Im also going to get new fuel lines the old ones like like crap.
Old 10-04-2011, 06:46 PM   #5
notyo_cheez
Poor or no ground is typical with fuel gauges, looks like you found your problem.
It's up to you if you want a new tank. Etch this one, apply a coating and re-use it if that's the worst of it.
Yes your friend is an idiot. Pressure wash, etch and paint the outside. I recommend engine enamel, it will always stay clean and won't rust, ever. Same for the shield.
notyo_cheez is offline   Reply With Quote
Old 10-04-2011, 08:29 PM   #6
lilpoindexter
lilpoindexter's Avatar
lilpoindexter is offline   Reply With Quote
Old 10-04-2011, 09:35 PM   #7
Pop's C-10
Pop's C-10's Avatar
you can use a gas tank sealer kit to coat tha inside of tha tank..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 10-04-2011, 09:46 PM   #8
Rogue_Alphonse
Rogue_Alphonse's Avatar
Originally Posted by lilpoindexter View Post
x2. That's like someone telling me the caked on oil and dirt on JUST the front of my rear axle is the same coating.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 10-04-2011, 09:50 PM   #9
Corts60
Just here to tinker
Corts60's Avatar
Yep. That's how they look.
Old 10-04-2011, 11:46 PM   #10
rayfinseats
That tank is CLEAN on the inside. I've run much worse. "I think my buddy is a idiot" HAHAHAHA.
rayfinseats is offline   Reply With Quote
Old 10-06-2011, 07:36 PM   #11
turbo350
Looks good to me inside and out. Any pointers for helping the process of loosening the bolts and straps?
turbo350 is offline   Reply With Quote
Old 10-07-2011, 02:31 AM   #12
jesse977
jesse977's Avatar
Check this out..http://forum.73-87chevytrucks.com/sm...ic,9294.0.html
