Old 08-11-2011, 08:05 PM   #51
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Re: 1966 K20 Project
A few better pictures and some small finish work.
VAC/Tach Gauge Cluster - Polished up the Chrome a little. Now it is hard to take pictures!
Factory AM Radio - I picked this up and just cleaned it all up. It has a couple of small pits in the original chrome. I will rechrome the face at a later date.
1966 Deluxe Steering Wheel - I picked this up and have plans to do it custom with Gloss Black in the center and Satin Black on the top and bottom. The Gloss and Satin will be seperated by the stainless rings.
LeftCoast32 is offline   Reply With Quote
Old 08-11-2011, 11:02 PM   #52
tommys66
Grill and gauges look awesome!
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 08-12-2011, 11:11 AM   #53
LeftCoast32
Custom Builder
Thanks!
Everything is getting done slowly. I only work on the parts as I have spare time with my business.
We have the Front Fenders, Grill Surround, 3 Cowl Pieces and door panels finished in DP.
We are still working on the Doors and Hood before starting on the Cab.
We are straightening the metal as much as possible before the DP is shot.
Once all the metal work is done we will get it all shot in High Build Primer and start Block Sanding the front sheet metal.
The Bed will be last. I still have to disassemble the bed I have now for the sides. I have a '72 Steel Bed Floor that I will use, I am not a fan of the wood floors in a shop truck that gets used all the time.
I will use Mar-K for the Front Bed Panel, Tailgate and then the Inner Fenders from the 67-72 bed to match the '72 Steel Bed Floor I have.
Old 09-14-2011, 12:32 PM   #54
LeftCoast32
Custom Builder
Up For Sale - http://67-72chevytrucks.com/vboard/c...p?product=5750
Old 09-14-2011, 09:12 PM   #55
LeftCoast32
Custom Builder
Originally Posted by LeftCoast32 View Post
Everything in this thread goes with it for the asking price in the for sale section. This includes everything from the '64 parts truck (no frame), and all the other parts like axles, wheels, other restored and chrome parts..
Old 09-16-2011, 01:45 PM   #56
LeftCoast32
Custom Builder
More pictures added to the for sale section - http://67-72chevytrucks.com/vboard/c...p?product=5750
Old 10-04-2011, 08:56 PM   #57
LeftCoast32
Custom Builder
Started on the Floor Repairs.
Last week we cut out the rockers, partial floors, cab corner (1) and kick panels and ran it over for a touch up on the Media Blasting.
Today we cut the patch panels to fit and started stitch welding them in. We are using TIG and will blend all the welds so the repairs disappear.
Old 10-05-2011, 08:38 AM   #58
duallyjams
duallyjams's Avatar
Does this mean its a keeper now.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-05-2011, 08:47 AM   #59
LeftCoast32
Custom Builder
I will continue to build it. This is one of my favorites so I wont be upset if it stays. I guess it boils down to if it sells, it is worth alot more finished then as a project. I have everything to finish it now. I just need the time to get everything done.
Old 10-05-2011, 07:05 PM   #60
LeftCoast32
Custom Builder
More Pictures
We were able to get a little more done with the floors today.
The grey paint in the pictures is cold zinc. It is applied to keep any surface rust down until it makes it over for DP90 and High Build Primer.
Old 10-06-2011, 09:55 PM   #61
LeftCoast32
Custom Builder
I was only able to stay around long enough to help fit the floor panel today. John did all the welding and blending in my absence. It is turning out great!
We will work on it again tomorrow and hope to have all the welds blended inside.
Then we will work on getting the gas filler hole patched and the rockers hung. It will take 3 of us to hold the doors (gapped) and set up the rockers, this takes a little more time.
Old 10-09-2011, 10:22 AM   #62
LeftCoast32
Custom Builder
We spent the day yesterday splitting and reforming the rockers to fit the cab. 10 hours working on the rockers is a little excessive but they really turned out great. Every one of the seams where they meet the body had to be split and welded.
3 of us worked together to hold the doors in place and align the rockers before welding them to the body. The fit is great now!
We will be taking a few days off and will get back on it on Tuesday first thing. We have between 1-1.5 days of work left getting everything ready for DP and High Build Primer.
We have to finish blending the TIG for all the spot welds.
We have to fit the bottoms of the rockers to the inner rockers.
We have to weld in a cab corner patch also.
Lastly we have to roll it on its back and blend off all the welds underneath the floors.
I want to thank my friends Tony and John for all the help and great work on the cab.
Old 10-09-2011, 07:40 PM   #63
duallyjams
duallyjams's Avatar
That will definitely be one cherry cab when you are done.
James
IG duallyjams
Old 10-10-2011, 01:36 AM   #64
LeftCoast32
Custom Builder
Thanks! We are taking our time trying to do it right. The nice thing is I have a great cab on the truck now. I may take the other cab and offer it up with the same work dont to it. The cab on the truck now is a Small Back Window with the 4 Speed Floor.
Old 10-11-2011, 08:12 PM   #65
LeftCoast32
Custom Builder
Got a little more done on the Cab today.
The rockers are now fully welded in top and bottom.
We blended the spot welds in the door opening.
Old 10-12-2011, 09:10 PM   #66
LeftCoast32
Custom Builder
We were able to get a few more hours on the Cab today.
Cab Corner is all welded and blended.
We had a patch that was needed in the B-Pillar (Sail Panel). It is all welded in and blended.
We patched the Gas Filler Hole in the cab.
We took the cab off the stand so we could work on a few dents on the roof.
We will be rolling it on its back to dress up all the welds on the bottom of the cab tomorrow.
Everything is looking great at this point.
Old 12-07-2013, 05:41 PM   #67
Auctioneerhere
How did the truck handle with the bigger tires & the factory springs?
Auctioneerhere is offline   Reply With Quote
Old 12-07-2013, 08:28 PM   #68
TJ's Chevy
TJ's Chevy's Avatar
Nice work on the cab!
Old 12-07-2013, 08:54 PM   #69
67swb72klb
67swb72klb's Avatar
this is an old thread
no up dates for 2 years
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 07-08-2015, 07:43 AM   #70
mcmlxix
Collector of Projects
mcmlxix's Avatar
These are the Steel Wheels I had made up in 17X9 with 5" of backspace. They have to clear a D60 and 14B FF with Disc Brake Conversion. They fit like a glove over the brakes and steering.
The plan is to run the real long chrome lugs front and rear.
I am going to run a set of real thin Stainless Steel Trim Rings.
The Dana 60 Mile Marker Hubs are Polished Stainless Steel.
The 14Bolt FF will have Polished Stainless Steel Axle Shaft Bolts.
Should look pretty good when finished.
They are a little dusty from setting around in the garage.
Can you tell us where you got the wheels made?
Rich
1972 K5 Blazer CST Click HERE
Old 07-08-2015, 08:29 AM   #71
Lokin4AReason
Lokin4AReason's Avatar
looking good and nice progress =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 02-10-2016, 07:59 PM   #72
sampsmit000
sampsmit000's Avatar
Like the build a lot. I also have an original 4x4. Mine is a 1964.
1964 Chevy Factory K10 Short Bed
Mitchell Sampson
sampsmit000 is offline   Reply With Quote
Old 02-11-2016, 12:46 AM   #73
sokoloka
I know this is a dead thread but was wondering the exact same thing ...
sokoloka is offline   Reply With Quote
