Old 10-03-2011, 10:40 PM   #1
62 Bowtie
62 Bowtie's Avatar
wheel size question
anyone know are wheel sizes actual? I ordered a set of wheels 15x7 for the 62 they say 15x7 on the box, when i measure the width its 8in is this correct or should they be 7in? thanks dudes
62 Bowtie is offline   Reply With Quote
Old 10-03-2011, 10:43 PM   #2
geezer#99
geezer#99's Avatar
Re: wheel size question
It's correct. 7" is measured from the bead surface to bead surface. Usually if you measure total rim width minus 1" equals the advertised rim width.
Old 10-03-2011, 10:51 PM   #3
62 Bowtie
62 Bowtie's Avatar
thank you geezer
Old 10-05-2011, 11:46 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
That's actually an important measurement to take into account when fitting wheels, etc. The width of the wheel is indeed the inside or bead mount to bead mount dimension, which means the overall width outside lip to outside lip is often an entire 1" wider.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-05-2011, 11:45 PM   #5
blackedoutharley
True, and because the rim width (where the bead seats) affects the section width of the tire the true overall width of the wheel must be accounted for.
blackedoutharley is offline   Reply With Quote
