![]() Join Date: Sep 2011
Fuel Gauge Issue
My fuel guage wouldn't go above a quarter of a tank. The truck came with an extra sending unit, which looked somewhat used, so I changed it out this past weekend. It worked perfectly until today when I filled the tank up for the first time since changing it out. Now the gauge acts exactly like it used to.
Any suggestions??? Posted via Mobile Device
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
Re: Fuel Gauge Issue
Check your grounds and clean any terminals. I had mine not going all the way full and I cleaned up all of the connections and it works good now.
1966 Chevy C-10 350 Engine 700R4 |
Thank you. I'll give that a try.
Same problem here. Found some info on the net about an original sending unit with a newer gauge. A resistor needs to be put inline. The site also mentioned using a pot. inline to fine tune it. I've not got around to trying it yet but I think I saved the link to the info. I'll post it here if I have it.
Posted via Mobile Device |
